Client Suite 2.2 Connectivity
Posted: Sun Jul 24, 2011 11:18 pm
by Bryan
Hello:
Something I noticed with the Client Suite 2.2. If the power to the RA controller is disrupted the client will still show connected at the bottom left of the screen (green), even hours later. If power to the controller is resumed, a stop and start is required of the listener service. Shouldn't the client report a "unable to connect notification at the bottom left of the screen shortly after the RA controller loses power?
Cheers
Re: Client Suite 2.2 Connectivity
Posted: Mon Jul 25, 2011 9:45 pm
The "Connected" message is not really connection with the controller, but the Client connected to the Listener Service.
Posted: Mon Jul 25, 2011 11:22 pm
by Bryan
Aah I see, is there a way to quickly "re-establish" the connection to the controller, rather than stop and starting the services?
Posted: Tue Jul 26, 2011 8:25 am
by dmolton
Bryan, it's been awhile since I tested it but there is an internal timer inside the Listener service. So long as the service is running it should attempt to make a connection with the information you provide. If it cannot, the countdown begins and tries again once it hits zero. This will happen indefinitely until either a connection can be made or the service is stopped. If a connection is made successfully and then dropped - the countdown timer logic should kick in again.
There will be a delay on the Client when this happens. Most likely you will stop seeing updates while the Listener tries to reconnect with the controller. Once its re-established the Client should start automatically updating again.
If this is not the behavior you are seeing, let me know. I will test out the scenario again either today or tomorrow. I forget, are you connected over USB or WiFi?
Posted: Tue Jul 26, 2011 1:47 pm
by Bryan
Hi Dave, I am using the USB cable for now. Basically if the power to the controller is disrupted and then restored it will not reconnect with the client. I have left it for hours and no connection is re-established. Only way is to stop and start the listener and logger. Not a biggie, but would be nice if it could re-establish a connection.
