Every time I try and set the "Heater On" temp to anything above 76.7F it auto-sets to 102.2F and causes the Heater port to toggle on and off every couple of seconds as the temp in my sump fluctuates around my Heater Off Temp.
I've tried updating temps via the web portal and I uploaded new code from my computer with the temps set the way I want and I still have the issue.
Ideas?
Heater Issue
Re: Heater Issue
Its the code generated by the wizard. Goal temps of 78 on, 79 off on port 6. I'll post the specific code later tonight.
:EDIT: Here's the code:
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.DayLights( Port1 );
ReefAngel.ActinicLights( Port2 );
ReefAngel.StandardATO( Port3 );
ReefAngel.Relay.DelayedOn( Port4 );
ReefAngel.Portal( "pyroboy1der" );
All the variables are stored in Internal Memory so I'm not sure how to pull them to post here.
Re: Heater Issue
If anybody knows how to pull the variables from the internal memory that would be awesome otherwise i can just re-generate the code with the variables in the code for now.
