second temp probe not displaying on T2
Posted: Sat Sep 22, 2012 10:03 pm
Need some help with second temp probe not displaying temp. I have swapped both probes to between port 1 and port 2 the new temp probe does not show temp now matter where it is plugged in.
Here is the code.
byte buzzer=0;
byte overheatflag=0;
byte atoflag=0;
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port3Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit;
ReefAngel.StandardATO( Port1 );
ReefAngel.DosingPumpRepeat1( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.Relay.Set( Port4, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.WavemakerRandom1(Port5,20,60); // Turn Port5 on/off random cycles that lasts from 20 to 60 secs
ReefAngel.WavemakerRandom2(Port6,20,60); // Turn Port6 on/off random cycles that lasts from 20 to 60 secs
// Port 5 and 6 are not synchronized.
// They work independent of each other at random times.
buzzer = overheatflag + atoflag;
if ( buzzer >= 1 ) buzzer = 100;
ReefAngel.PWM.SetDaylight( buzzer );
ReefAngel.PWM.SetActinic( buzzer );
ReefAngel.Portal( "riggeek" );
int x,y;
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
Here is the code.
byte buzzer=0;
byte atoflag=0;
int x,y;
// Salinity
