Page 1 of 4
New System
Posted: Mon Sep 24, 2012 12:01 pm
by smcglaughn
I just got my system and hooked it up. I was careful following the instructions, I think. However I can not get my controller to communicate with my computer. It shows connected my computer but will not let me change any code. Can anyone give me some guidance?
Re: New System
Posted: Mon Sep 24, 2012 12:09 pm
Can you post the error message you are getting?
Which board do you have? RA or RA+?
Sent from my Galaxy S3 using Tapatalk 2
Re: New System
Posted: Mon Sep 24, 2012 12:26 pm
by smcglaughn
I cant get the error code copied to paste. Here is the code I tried to enter. How do I get the error code to copy and paste?
// Autogenerated file by RAGen (v1.2.2.171), (09/24/2012 14:17)
// RA_092412_1417.pde
#define VersionMenu
#define WDT
#define SIMPLE_MENU
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port4);
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
ReefAngel.StandardLights(Port8);
Re: New System
Posted: Mon Sep 24, 2012 12:29 pm
You need to use shortcut key to copy.
Select the text and use Ctrl+C.
Re: New System
Posted: Mon Sep 24, 2012 1:37 pm
by smcglaughn
I have the RA
Re: New System
Posted: Mon Sep 24, 2012 1:39 pm
by smcglaughn
Watchdog Timer
Version Menu
Simple Menu
In file included from RA_092412_1538.cpp:30:
C:\Users\SteveO\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:86: error: 'ParamsStruct' does not name a type
C:\Users\SteveO\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:88: error: 'RA_NokiaLCD' does not name a type
C:\Users\SteveO\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:89: error: 'RA_JoystickClass' does not name a type
C:\Users\SteveO\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:90: error: 'LEDClass' does not name a type
C:\Users\SteveO\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:92: error: 'RA_ATOHighClass' does not name a type
C:\Users\SteveO\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:93: error: 'RA_ATOLowClass' does not name a type
C:\Users\SteveO\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:94: error: 'RA_TempSensorClass' does not name a type
C:\Users\SteveO\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:95: error: 'RelayClass' does not name a type
C:\Users\SteveO\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:133: error: 'TimerClass' does not name a type
C:\Users\SteveO\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:302: error: 'Total_Menus' was not declared in this scope
C:\Users\SteveO\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:303: error: 'Total_Menus' was not declared in this scope
RA_092412_1538.cpp: In function 'void setup()':
RA_092412_1538.pde
error: 'class ReefAngelClass' has no member named 'Relay'
RA_092412_1538.pde
error: 'Port1' was not declared in this scope
RA_092412_1538.pde
RA_092412_1538.pde
error: 'Port2' was not declared in this scope
RA_092412_1538.pde
RA_092412_1538.pde
error: 'Port3' was not declared in this scope
RA_092412_1538.pde
RA_092412_1538.pde
error: 'Port4' was not declared in this scope
RA_092412_1538.cpp: In function 'void loop()':
RA_092412_1538.pde
error: 'Port5' was not declared in this scope
RA_092412_1538.pde
error: 'Port6' was not declared in this scope
RA_092412_1538.pde
error: 'Port7' was not declared in this scope
RA_092412_1538.pde
error: 'Port8' was not declared in this scope
Re: New System
Posted: Mon Sep 24, 2012 1:58 pm
Looks like you got your libraries messed up somehow.
I'd recommend deleting the folder "Documents\Arduino" and reinstalling the RA Installer software to restore the original libraries files.
Re: New System
Posted: Mon Sep 24, 2012 3:18 pm
by smcglaughn
I deleted the "Documents\Arduino" and reinstalled the RA Installer software. I tried loading more code and got this error message.
Watchdog Timer
Version Menu
Simple Menu
In file included from sketch_sep24a.cpp:6:
C:\Users\SteveO\Documents\Arduino\libraries\NokiaLCD/NokiaLCD.h:5:22: error: WProgram.h: No such file or directory
In file included from sketch_sep24a.cpp:7:
sketch_sep24a.cpp: In function 'void loop()':
sketch_sep24a:13: error: 'class ReefAngelClass' has no member named 'LED'
sketch_sep24a:15: error: 'class ReefAngelClass' has no member named 'LED'
Re: New System
Posted: Mon Sep 24, 2012 3:30 pm
What OS are you using?
Did you download the latest Reef Angel Installer from the website?
You seem to be using outdated/wrong libraries still.
Re: New System
Posted: Mon Sep 24, 2012 3:32 pm
by smcglaughn
Windows 7. I went to the top of the page and downloaded it straight from the website.
Re: New System
Posted: Mon Sep 24, 2012 4:41 pm
I'm sorry... I didn't read your code correctly.
Can you please use the Reef Angel Wizard to generate new codes?
The RAGen is an old application and should not be used anymore. It has been deprecated and will be removed from the installer too.
Use menu Tools->Reef Angel Wizard
Re: New System
Posted: Mon Sep 24, 2012 5:34 pm
by smcglaughn
All I get is a welcome screen with this on it. Nothing else. No place to click to continue nothing.
Welcome to the Reef Angel Wizard. I'm going to walk you through the whole process of generating a code for your Reef Angel Controller. Version: 2.1.0.
Re: New System
Posted: Mon Sep 24, 2012 5:54 pm
You don't see the buttons at the bottom?
Re: New System
Posted: Mon Sep 24, 2012 5:56 pm
by smcglaughn
No. It will not let me scroll down either?
Re: New System
Posted: Mon Sep 24, 2012 7:56 pm
Are you using a small screen resolution?
Re: New System
Posted: Tue Sep 25, 2012 7:48 pm
by smcglaughn
I only have 2 choices on resolution and both are cutting off the bottom of the page. When I try to drag the screen up to see the bottom it won't let me.
Re: New System
Posted: Tue Sep 25, 2012 7:54 pm
What screen resolution are you using?
Re: New System
Posted: Tue Sep 25, 2012 8:01 pm
by smcglaughn
1024X600 I can change it to 800X600 those are my only choices.
Re: New System
Posted: Tue Sep 25, 2012 10:19 pm
Yeah, you won't be able to use the Wizard at this resolution.
I can generate the code for you if you tell me what you would like to do.
Re: New System
Posted: Wed Sep 26, 2012 10:08 am
by smcglaughn
I Aappreciate the help but I still think I have a communication issue. What I want on my code is: ports 1 through 4 always on. Port 5 &
6 wavemakers. Port 7 heater. Port 8 refugium light on at 5pm off at 1 pm. Thanks.
Re: New System
Posted: Wed Sep 26, 2012 10:15 am
What is the heater temperature?
Re: New System
Posted: Wed Sep 26, 2012 11:03 am
by smcglaughn
76 degrees.
Re: New System
Posted: Wed Sep 26, 2012 11:54 am
Try this code.
It should compile at least and if you are indeed having problems uploading, the error code will be different.
ReefAngel.Wavemaker(Port5,60);
ReefAngel.Wavemaker(Port6,120);
ReefAngel.StandardHeater(Port7,757,763);
ReefAngel.StandardLights(Port8,17,0,13,0);
Re: New System
Posted: Wed Sep 26, 2012 6:48 pm
by smcglaughn
That worked. Thanks for your help. What program can I use to see on my computer what information is stored on the controller? I tried Reef Angel Client but it doesn't seem to be working?
Re: New System
Posted: Wed Sep 26, 2012 6:50 pm
Oh, the Client needs one line to be added to your code.
Use this:
ReefAngel.AddWifi();
Re: New System
Posted: Wed Sep 26, 2012 7:31 pm
by smcglaughn
I added this and it was successfully installed. However i am still not getting data to show up on the client. It does work through the USB??
Re: New System
Posted: Wed Sep 26, 2012 7:36 pm
Yes, it works through USB.
You need to select the correct COM port though.
Go to menu Settings->Modify->General and open the dashboard.
Make sure you pick the same COM port you use to upload codes to RA.
Re: New System
Posted: Wed Sep 26, 2012 7:44 pm
by smcglaughn
That got it. Thanks.
Re: New System
Posted: Thu Oct 04, 2012 4:43 pm
by smcglaughn
I got calibration solutions for my PH probe. 7 PH and 10 PH. Originally my probe showed 1.42. Obviously wrong. My tanks is staying at 76 degrees and my Salinity is 1.025. I tried to calibrate the probe. I followed the instructions and the used the 7 solution. then moved to the 10 solution. As soon as I hit okay. I went back to the home screen. With the probe still in the 10 PH solution the PH meter is only reading 6.99. I cleaned the probe with RO water and put it in the Aquarium and it still reads 6.99. I put it back in the 10 PH solution and it still reads 6.99. Is my probe bad?
Re: New System
Posted: Thu Oct 04, 2012 5:12 pm
What were the numbers you had when doing the calibration?
