Rf
reefcycle
Rf
Post by reefcycle »
Last problem post I swear. I had RF setup before and thanks to Roberto I figured out that I am a moron. Lol. But when I first plugged in RF it was already solid purple. I have RA+ is there something im missing? I had this setup for long time and I feel like a newb when I have to tweak things.
Re: Rf
It should be good.
Why do you think you may be missing something?
reefcycle
Re: Rf
Post by reefcycle »
Can't link them. Don't I need it flashing to make pumps slaves
Re: Rf
Ahh, if you are trying to sync them, you need to load the VortechSetup code.
File->Sketchbook->Example Codes->VortechSetup
Then, follow the manual for syncing instructions.
reefcycle
Re: Rf
Post by reefcycle »
linked vortechs. also linked water level. what a day! heres my question, on forums portal I change modes and it says ok and done, but no speed change. what I do wrong?
Re: Rf
Can I see your code?
You must use UseMemory=true to be able to change on the Portal
ReefAngel.RF.UseMemory=true;
reefcycle
Re: Rf
Post by reefcycle »
I will attempt when I get home @ 545. But I will say one thing since I upgraded to RA + and used wizard instead of old method my heater port 3 was not auto engaging either. Lol I am so not a helpless person usually but I am so lost. And I must thank you rimai for all your help
reefcycle
Re: Rf
Post by reefcycle »
ok since I am a newb at code, how can I send you my code with out going nuts trying to unplug everything? Lol I am so lost.
Re: Rf
Not following....
You can just paste the code in here? :?:
reefcycle
Re: Rf
Post by reefcycle »
But I made code then added water level and RF so how do I copy and paste whole code?
dbmet
Re: Rf
Post by dbmet »
Open the Arduino App and highlight your code and right click and copy if your on a windows computer?
Then Paste it here for him to see..
d
reefcycle
Re: Rf
Post by reefcycle »
not sure if this is latest but it is close.
#include <avr/pgmspace.h>
RA_NokiaLCD e;
    e.Init();
    e.BacklightOn();
    InternalMemory.OverheatTemp_write( 829 );
    InternalMemory.StdLightsOnHour_write( 0 );
    InternalMemory.StdLightsOnMinute_write( 0 );
    InternalMemory.StdLightsOffHour_write( 18 );
    InternalMemory.StdLightsOffMinute_write( 0 );
    InternalMemory.ActinicOffset_write( 0 );
    InternalMemory.HeaterTempOn_write( 760 );
    InternalMemory.HeaterTempOff_write( 765 );
    InternalMemory.ChillerTempOn_write( 775 );
    InternalMemory.ChillerTempOff_write( 770 );
    InternalMemory.DP1RepeatInterval_write( 60 );
    InternalMemory.DP1Timer_write( 30 );
    InternalMemory.DP2RepeatInterval_write( 65 );
    InternalMemory.DP2Timer_write( 30 );
    InternalMemory.IMCheck_write(0xCF06A31E);
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+20, MENU_START_ROW*3, "Memory Updated");
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*6, "You can now");
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*7, "upload your");
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+33, MENU_START_ROW*8, "INO code");
Re: Rf
nope. not it
reefcycle
Re: Rf
Post by reefcycle »
Sigh
reefcycle
Re: Rf
Post by reefcycle »
How about I start over. When I goto reef angel select wizard and start from scratch should I do set for code (new users) or set internal memory? After that I select my settings for port 1 time schedule port 2 time schedule port 3 heater port 4 fan port 5 & 6 unused port 7 dosing pump 1 and port 8 dosing pump 2. RF vortech reefcrest and set internal generate successful.
After I did that I resynced the vortechs since they and the RF module where not there and reset water level out of water and in water. When all said and done I have on android app water percentage temp Ph etc. Heaters I have to override lights are way off and need to be manually set and I can read and write memory on android app but when everything set to auto it is either all on or off. On portal it is showing way off options. I know this is something I am doing g completely wrong and I feel so helpless.. do any of those steps sound ridiculous?
Re: Rf
If you want to be able to change settings on the portal or android app, you must choose to store settings on internal memory.
This is what is going to place the correct settings in the memory and should also show the correct settings on both Portal and Android.
If you don't choose internal memory, all apps are just going to start pulling whatever crap is currently stored.
Then at the end, it will show you the code you uploaded, which you can save if you wish or not. You can always generate it again.
reefcycle
Re: Rf
Post by reefcycle »
I did that the second time. I will try again when im not exhausted. Ty. I will try again
reefcycle
Re: Rf
Post by reefcycle »
oh here is the latest made code, with port settings and times and vortech control.
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
    ReefAngel.DayLights( Port2 );
    ReefAngel.StandardFan( Port4 );
    ReefAngel.Portal( "reefcycle" );
    int x,y;
    // I/O Expansion
    byte bkcolor;
    x = 14;
    y = 21;
    for ( int a=0;a<6;a++ )
      if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE; else bkcolor=COLOR_GRAY;
    ReefAngel.LCD.DrawMonitor( 15, 46, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 46, ReefAngel.Params );
Re: Rf
Good.
You are missing the RF stuff, so just add this to your loop():
reefcycle
Re: Rf
Post by reefcycle »
I add that at the end? where shall I put it?
Re: Rf
reefcycle
Re: Rf
Post by reefcycle »
perfect, one question. got the vortechs working. one question I have water level sensor setup but its not at moment. When I add the code to the RA for expansion I lose my settings
Re: Rf
Can you rephrase?
reefcycle
Re: Rf
Post by reefcycle »
water level isnt in the wizard so I have to add the code to RA so I get everything workign except water level with posted code
Re: Rf
Correct, all you need to do is manually add the water level stuff now.
reefcycle
Re: Rf
Post by reefcycle »
where shall I put it? I am looking at the code that worked and not wanting to lose all my progress. I am sorry roberto, I am going to be adding relay expansion since I need more amperage draw for lights and heaters. So I am at least buying stuff lol
Re: Rf
Use this:
  int x,y;
  // I/O Expansion
  byte bkcolor;
  x = 14;
  y = 21;
    // Water Level
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,76, "WL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,76, ReefAngel.WaterLevel.GetLevel() );
reefcycle
Re: Rf
Post by reefcycle »
before I mess anything up, this should be sent to RA as is and is all my code or is it need me to add anything else.
reefcycle
Re: Rf
Post by reefcycle »
ok posted and water level is there but no vortech control from portal and that custom code is there
NVM now it works! roberto u r the man I am sorry I am so slow
Re: Rf
Cool :)
