Sketch too big
Posted: Mon Oct 15, 2012 10:12 pm
by dtzreef
Hey everyone....after a bunch of cutting and pasting, I came up with this code but it is a little too big and I cannot figure out what else I can cut out. Please help. Also, I plan on setting my wifi up soon, will this be a problem with a sketch this size? I really haven't learned the wifi stuff yet but thought I would ask. Thanks for the help!
byte wmport=Port5;
boolean wmdelay=false;
#include <avr/pgmspace.h>
prog_char menu6_label[] PROGMEM = "Lights On";
prog_char menu7_label[] PROGMEM = "Lights Off";
prog_char menu8_label[] PROGMEM = "Date/Time";
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
for ( byte i = 0; i < MAX_RELAY_EXPANSION_MODULES; i++ )
ReefAngel.Relay.RelayMaskOnE = ReefAngel.LightsOnPortsE;
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry7()
ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE = 0;
#endif // RelayExp
void MenuEntry8()
ReefAngel.SetupDateTime();
ReefAngel.LCD.DrawDate(6, 120);
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 4, 4 , "DTZ REEF ANGEL");
ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 75, 119, 75);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 118, 119, 118);
ReefAngel.LCD.DrawText(COLOR_GOLDENROD, COLOR_WHITE, 8, 15, "Main Tank:");
char text[7];
ReefAngel.LCD.DrawText(COLOR_GOLDENROD, DefaultBGColor, 88, 15, text);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 50, 46, "pH:");
ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 88, 46, text);
ReefAngel.LCD.DrawText(COLOR_RED, COLOR_WHITE,8,25,"Room Temp:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_RED, 88, 25, 10);
ReefAngel.LCD.DrawText(COLOR_DARKORCHID, COLOR_WHITE,8,36,"Refugium:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor, 88, 36, 10);
// Display arrows for Wavemaker
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 38, 57,"WAVE FLOW:");
if (bitRead(ReefAngel.Relay.RelayData,Port5-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67,"----->"); //port 5 on
else if (bitRead(ReefAngel.Relay.RelayData,Port6-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67,"<-----"); //port 6 on
else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67," 00000 "); //port5 and port 6 off, wavemaker delay
//show the timer for wavemaker
int t=ReefAngel.Timer[1].Trigger-now();
if (t>=0)
ReefAngel.LCD.Clear(255,105,64,135,74);
ReefAngel.LCD.DrawText(APColor, COLOR_KHAKI,105,64,t);
// ReefAngel.LCD.DrawGraph(5, 5);
ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(30,45));
ReefAngel.Timer[1].Start();
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 805 );
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port8);
ReefAngel.StandardATO( Port1,600 );
ReefAngel.Relay.DelayedOn( Port2,5 );
ReefAngel.StandardLights( Port3,9,0,21,0 );
ReefAngel.StandardLights( Port4,10,0,20,0 );
ReefAngel.StandardHeater( Port7,770,790 );
//wavemaker timers and slow down at night
if ((hour() >= 21) || (hour() <= 8)) //from 9p-8a
if (wmdelay)
ReefAngel.Timer[1].SetInterval(60); // wm night delay
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
if (wmport==Port5) wmport=Port6;
else wmport=Port5;
wmdelay=false;
ReefAngel.Timer[1].SetInterval(20); // short wave
ReefAngel.Relay.On(wmport);
wmdelay=true;
//8a-9p normal wave settings
ReefAngel.Timer[1].SetInterval(random(35,50));
if bitRead(ReefAngel.Relay.RelayData,Port5-1) ReefAngel.Relay.Off(Port6);
else ReefAngel.Relay.On(Port6);
ReefAngel.Portal( "Dtzreef" );
ReefAngel.LCD.BacklightOn();
Re: Sketch too big
Posted: Mon Oct 15, 2012 11:13 pm
by alexwbush
Is this from the RA wizard? I'm not sure because I've never used wavemaker functions. If it's not, I'd recommend trying to replicate using the wizard and see how large the file is. I don't remember so much menu coding on standard setup.
Re: Sketch too big
Posted: Tue Oct 16, 2012 1:46 am
by dtzreef
It has a custom main screen from Psyrob and a custom menu with Roberto's help. I tweaked and adjusted both parts using RA wizard and other posts as a guide. I am definitely still learning with everyones help.
Re: Sketch too big
Posted: Tue Oct 16, 2012 7:57 am
get rid of setup date time
Re: Sketch too big
Posted: Tue Oct 16, 2012 11:06 am
by dtzreef
So I'm guessing there isn't much else I could remove because how then, would I adjust the date and time? Do I need the upgraded RA board because I haven't even tackled the wifi stuff yet?
Re: Sketch too big
Posted: Tue Oct 16, 2012 12:12 pm
by alexwbush
You shouldn't have to mess with the date and time much. Only time I ever did was for daylight savings... but I think that might be fixed now.
Re: Sketch too big
Posted: Tue Oct 16, 2012 9:08 pm
by dtzreef
You are right, I would have to only change it twice a year for DST. Not too bad. I am worried that I should have got the RA+ since I am already getting "sketch too big" messages. I guess after all these years of reefing I still haven't learned that lesson. Spend more because you're gonna want to upgrade later anyway.
Re: Sketch too big
Posted: Tue Oct 16, 2012 9:15 pm
Also, with the wifi, you can sync the time with android or portal. One click and you are done.
Re: Sketch too big
Posted: Tue Oct 16, 2012 9:30 pm
by dtzreef
Perfect
