Clouds and Lightning
Posted: Sat Oct 20, 2012 7:43 pm
by dbmet
Any idea If I'm close to gettting the clouds to work ? I would like the duration and Next cloud to show on the screen..
Here is my code
#define Fan 8
#define LightWhite 7
#define Main Pump 6
#define Skimmer 5
#define Heater 4
#define Powerhead 3
#define ATO 2
#define LightBlue 1
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define CUSTOM_VARIABLES
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
byte x = 6;
byte y = 2;
byte t;
char text[8];
// Parameters
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,12,16,"Daryls 90 Reef",
Font8x8);
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255,10,30,"TANK");
ReefAngel.LCD.DrawLargeText(COLOR_PURPLE, 255, 10, 40, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,100,30,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_PURPLE, 255, 85, 40, text, Num8x16);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,100, "WLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119,
ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawText(0,255,88,100, "BLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119,
ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.DrawText(0,255,48,100, "Cloud");
ReefAngel.LCD.DrawText(0,255,41,108, "Duration");
ReefAngel.LCD.DrawText(0,255,60,40,PWMSlope(20,2,6,0,0,100,255,0));
ReefAngel.AddStandardMenu();
ReefAngel.FeedingModePorts = Port3Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit;
InternalMemory.ATOExtendedTimeout_write(120);
ReefAngel.Relay.On( Port3 );
ReefAngel.ActinicLights( LightBlue );
ReefAngel.SingleATOLow( Port2 );
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off (Port2);
ReefAngel.StandardLights( LightWhite );
ReefAngel.StandardFan( Port8 );
ReefAngel.StandardHeater( Port4 );
ReefAngel.Relay.DelayedOn( Port5 );
ReefAngel.Portal( "dbmet");
void CheckCloud()
#define Clouds_Every_X_Days 2
#define Cloud_Chance_per_Day 60
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 2
#define Max_Clouds_per_Day 4
// In this example, start could after 10:30am
#define Start_Cloud_After NumMins(10,30)
// In this example, end could before 5:30pm
#define End_Cloud_Before NumMins(17,30)
#define Lightning_Change_per_Cloud 0
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (lightningchance>Lightning_Change_per_Cloud) lightningchance=2;
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.DrawText(0,255,48,47,"Cloud");
ReefAngel.LCD.DrawText(0,255,48,57,"00:00");
//ReefAngel.LCD.DrawText(0,255,45,120,"L");
//ReefAngel.LCD.DrawText(0,255,51,120,"00:00");
int x=0;
if ((cloudstart/60)>=10) x=48; else x=54;
ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart/60));
if ((cloudstart%60)>=10) x=66; else x=72;
ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart%60));
ReefAngel.LCD.DrawText(0,255,56,119,cloudduration);
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
Re: Clouds and Lightning
Posted: Sat Oct 20, 2012 7:53 pm
Almost...
#define Fan 8
#define Main Pump 6
#define Skimmer 5
#define Heater 4
#define Powerhead 3
#define ATO 2
#define LightBlue 1
#define wifi
#define WDT
#define SIMPLE_MENU
#define CUSTOM_MAIN
  byte x = 6;
  byte y = 2;
  byte t;
  char text[8];
  // Parameters
  Font8x8);
  //  ReefAngel.LCD.DrawText(0,255,48,100, "Cloud");
  //  ReefAngel.LCD.DrawText(0,255,41,108, "Duration");
  //  ReefAngel.LCD.DrawText(0,255,60,40,PWMSlope(20,2,6,0,0,100,255,0));
  //  Moved to inside CheckCloud()
  ActinicPWMValue=ReefAngel.PWM.GetActinicValue();
  DaylightPWMValue=ReefAngel.PWM.GetDaylightValue();
  CheckCloud();
void CheckCloud()
  //  could happen.
  //  fit in that 510 minutes window.
#else
#endif
      if (cloudchance)
  if (cloudchance)
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
  ReefAngel.LCD.DrawText(0,255,60,40,cloudduration);
      int x=0;
      else x=54;
      else x=72;
      int x=0;
      else x=57;
      else x=75;
  cstart*=60;
  cend*=60;
Posted: Sun Oct 21, 2012 6:43 am
by dbmet
Wahoo thanks now lets see if it works later. Lol. Here's a picture of the screen
