Timeout error
Posted: Tue Oct 23, 2012 12:40 am
Today I updated libraries and try to upload a new code to my RA. Before I never had problems uploading.
arduino log:
my code:
Suggestions?
arduino log:
Watchdog Timer
Version Menu
Dimming Signal
RF Expansion Module
Wifi Attachment
Date/Time Setup Menu
Simple Menu
Dimensione del file binario dello sketch: 35.534 bytes (su un massimo di 258.048 bytes)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\TINOZ2~1.5\AppData\Local\Temp\build8625544596654132806.tmp\ott23.cpp.hex:i
avrdude: Version 5.11.1, compiled on Apr 1 2012 at 09:58:16
System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM3
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
ReefAngel.AddDateTimeMenu();
ReefAngel.AddWifi ();
InternalMemory.OverheatTemp_write( 309 );
ReefAngel.Relay.On( Port4 );
ReefAngel.LCD.DrawLargeText(COLOR_STEELBLUE,COLOR_WHITE,28,121,"Tinozzina"); // Display Reef Angel banner
ReefAngel.DayLights( Port2 );
ReefAngel.MoonLights( Port3 );
ReefAngel.StandardHeater( Port5 );
ReefAngel.StandardFan( Port6 );
ReefAngel.Relay.DelayedOn( Port7 );
if ( ReefAngel.RF.Mode != Feeding_Start)
if (hour()==9)
if (minute()>0)
ReefAngel.RF.SetMode( Lagoon,65,10 );
ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
else if (hour()==10 && minute()<5)
ReefAngel.RF.SetMode( Constant,90,10 );
else if (hour()==13 && minute()<30)
ReefAngel.RF.SetMode( Smart_NTM,90,3 );
else if (hour()==19 && minute()<5)
else if (hour()==20 && minute()<30)
else if (hour()==21)
else if (hour()>=22 || hour()<10)
ReefAngel.RF.SetMode( Night,80,10 );
ReefAngel.RF.SetMode( ReefCrest,75,10 );
ReefAngel.Portal( "stephy" );
