Wifi settings not able to be changed
Posted: Mon Oct 29, 2012 4:03 am
by eds
Bit of an interesting one (for me at least)
I figured that I have not configured my wifi properly as I don't get graphs on the portal. However it gets its IP, responds (95%) of the time when the android client connects and in general, works.
The issue is when I plug in my wifi adapter to the computer and neither Daves nor Roberto's tools can see my wifi expansion. I know the cable is good because I use it to program the reef angel plus. My code is currently generated stock from the wizard.
Any thoughts?
Re: Wifi settings not able to be changed
Posted: Mon Oct 29, 2012 6:58 am
When using Dave's you need to use 57600 baud.
Also, make sure that you click "Save Remote Settings" button too. This will enable the attachment sending data to the Portal.
Posted: Tue Oct 30, 2012 1:12 am
by eds
Interestingly enough, I loaded your app (fresh windows install) and it could not see my wifi adapter (kept telling me to unplug and plug it back in)
I loaded up Daves tool and it wouldnt read any of my info. I hit "Save Remote Settings" anyway and what do you know, it actually is sending data.
I am concerned that I can't get the PC to read its settings or connect to the app. Is there anything I can do to get it to register properly?
Posted: Tue Oct 30, 2012 8:07 am
Do you have Client software running?
If you do, it is what may be messing with the communication.
Posted: Tue Oct 30, 2012 11:01 pm
by eds
No, only had the reef angel tools installed. Its funny, When I request settings or something else I can see the lights flash and start to work, it just doesnt give me an output
