Lost Power
lartho6
Lost Power
Post by lartho6 »
Last night i lost power. which was no big deal but when the power came back on and i tried to make sure everything was fine with the controller, I had a issue with Client, its connected but im not able to use it.. when i go to launch service dash and save it i get a error reading. The configuration file has been changed by another program. C:\User\Dell\AppData\Roaming\ReefAngel\Client\ReefAngelClient.exe.Config I tried to find it but i cant it. It also say something about Jlt debugging.. but i have no clue on what to do.. i tried to uninstall it and redo it aegain but it still does the same thing
Re: Lost Power
If you uninstall, you have to also manually uninstall the services :(
There is a problem with uninstalling services that Dave is aware of, and the new release should take care of that.
http://forum.reefangel.com/viewtopic.php?p=12198#p12198
