WIFI cant be found wih utility
Posted: Fri Nov 02, 2012 1:22 pm
by butcherman
i connect the wifi unit with the cable to the pc and get this error
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM3
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM3
** ERROR - Please disconnect and then reconnect the Reef Angel Wifi Attachment from the USB-TTL cable and try again.
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
Any ideas?
Re: WIFI cant be found wih utility
Posted: Fri Nov 02, 2012 1:24 pm
Did you try a different Serial Port?
Posted: Fri Nov 02, 2012 1:35 pm
by butcherman
yes i did. also tried hard reset
Posted: Fri Nov 02, 2012 1:36 pm
by butcherman
also used 3 diffrent computers. the green light and blue lights no flash but still the same errors
Posted: Fri Nov 02, 2012 1:40 pm
by butcherman
should also be noted the wifi has been running for 4 months no issues
Posted: Fri Nov 02, 2012 1:57 pm
Does it blink orange when you click "Connect" ??
Posted: Fri Nov 02, 2012 10:02 pm
by butcherman
it was only blinking green slowly with an ocational orange blink, but i was seeing it on the network using a n app called fing to see ip's on the network. after hard reset, green and blue flash like as if i just bought it.
but still get ** ERROR - Please disconnect and then reconnect the Reef Angel Wifi Attachment from the USB-TTL cable and try again
Posted: Fri Nov 02, 2012 10:40 pm
by eds
This is exactly the same issue I am having. My wifi works fine but it can't be read when I need to make a change (which I do need to do soon)
Posted: Fri Nov 02, 2012 10:53 pm
by eds
I should add a trick for you butcherman. I can't connect with the wifi util to my unit, however if you use Dave's tool instead, while it won't read your settings or give you ANY feedback that its doing anything, the settings you apply to the unit are actually being applied. Its REALLY weird.
Posted: Sat Nov 03, 2012 1:47 am
by butcherman
eds wrote:I should add a trick for you butcherman. I can't connect with the wifi util to my unit, however if you use Dave's tool instead, while it won't read your settings or give you ANY feedback that its doing anything, the settings you apply to the unit are actually being applied. Its REALLY weird.
is this the grapical wifi tool?
Posted: Sat Nov 03, 2012 8:50 am
Yes, can you give Dave's utility a try?
You can get it on the contribution section of the website.
Also, would you be able to try Tera Term and see if your get any reply back from the module??
Posted: Sat Nov 03, 2012 9:05 am
by butcherman
installed it and got "?????" As a responce. It didn't take any setting either
Sent from my GT-I9100 using Tapatalk 2
Posted: Mon Nov 05, 2012 3:40 am
by butcherman
Problem sorted! :idea: I striped and cleaned the wifi board there was a white residue on it (maybe salt) work straight away.
