Led pendant stays on dim
Posted: Sat Nov 17, 2012 9:48 pm
by marc49127
I purchased some led pendants that are not controllable and plugged them into ports 4 and 5 where my T-5's were. When the lights go off they stay on very dim. Is there any ports other than 7&8 that turn off 100%?
Re: Led pendant stays on dim
Posted: Sun Nov 18, 2012 9:46 am
All ports are turned of 100%
Posted: Sun Nov 18, 2012 1:13 pm
by marc49127
Just tested the two ports I have my heaters plugged into and they still keep the leds on dim?
Posted: Sun Nov 18, 2012 2:17 pm
Ports 5 and 6 have special dampening components to help with inductive spike from wavemakers. I wonder if they are interfering with your pendant.
What happens if you plug it on a different port?
Posted: Fri Nov 30, 2012 5:36 pm
by mcgyvr
marc,
You sure its not a problem with your LED drivers? (leakage current/capacitance)
Just plug them into a wall for a bit and then unplug them and see if it still does it.
Maybe there are just some capacitors on the output that take a few minutes to drain thus keeping the LED's on for a little bit after.
Its highly unlikely that the relay contacts that turn off the outlet are not switching fully on/off. Relays are either on or off..no in between
