PH probe quit
Posted: Mon Nov 19, 2012 5:27 pm
by forced4
My RA was bought in October, and I just put the ph probe online in late September.. It started off out of the box being sluggish and now it won't give anything more than zero on the calibration screen. Nothing has changed in my code or hardware. I think its an issue with the probe. I tried cleaning it in vinegar with no luck. Can you give me any advice?
Phil
Sent from my PC36100 using Tapatalk 2
Re: PH probe quit
Posted: Mon Nov 19, 2012 8:29 pm
by forced4
Maybe there is more to this story... The ph seemed to jump up when ato was active earlier. It made it to about 5 then flatlined shortly after ato.
Re: PH probe quit
Posted: Mon Nov 19, 2012 8:54 pm
by DrewPalmer04
Float leak. You need a new float.
Re: PH probe quit
Posted: Tue Nov 20, 2012 5:31 am
by forced4
Is there a better float to purchase? This one is pretty new. Is the ph probe fried? Is there a better one? Just so i understand, are you saying I'm getting voltage in the tank from a float switch when ato is idle?
Re: PH probe quit
Posted: Tue Nov 20, 2012 5:57 am
Let's try this:
Get a cup and fill it with tank water then place the ph probe inside of it.
What kind of readings do you get?
Re: PH probe quit
Posted: Tue Nov 20, 2012 4:20 pm
by forced4
That didn't make a difference. Still shows ph of 1.28 (zero on calibration screen)
Re: PH probe quit
Posted: Tue Nov 20, 2012 5:25 pm
send me a pm for a RMA number
Re: PH probe quit
Posted: Tue Nov 20, 2012 7:14 pm
by forced4
pm sent
