bug????
Posted: Sun Nov 25, 2012 12:06 pm
by baroutas
Hi Roberto!!Yesterday Iuploade a code from wizard and i set the actinic port ''parabola'', start at 20:30 and end at 03:00. Evrethink looks OK exept the actinic port witch stay of. This is the code:
ReefAngel.OverheatShutoffPorts = Port1Bit;
InternalMemory.OverheatTemp_write( 355 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,278,280 );
ReefAngel.StandardFan( Port2,310,325 );
ReefAngel.MHLights( Port3,14,0,20,30,30 );
ReefAngel.MHLights( Port4,13,0,21,30,30 );
ReefAngel.DosingPumpRepeat( Port5,0,1240,10 );
ReefAngel.StandardLights( Port6,20,30,4,0 );
ReefAngel.PWM.SetDaylight( PWMSlope(13,0,21,30,0,100,60,0) );
ReefAngel.PWM.SetActinic( PWMParabola(20,30,3,0,0,70,0) );
ReefAngel.Portal( "baroutas" );
If this is a bug how i fixed????
Re: bug????
Posted: Sun Nov 25, 2012 12:47 pm
yeah :(
The parabola can't cross over to the next day.
It has to start and end in the same day.
Re: bug????
Posted: Sun Nov 25, 2012 1:22 pm
by baroutas
:( :?: ok i change it. Thanks for one more time!
Re: bug????
Posted: Sun Nov 25, 2012 2:49 pm
by fatman
Or set it for an incorrect time so that it will think it's on the same day for the hours you want. But that might make things difficult when you try to have other things with timed starts.
Re: bug????
Posted: Mon Nov 26, 2012 12:31 am
by baroutas
Yes that makes things difficult for me. Never mind parabola end at 23:59 now and it is ok!
