Ph probe add on
Posted: Sun Nov 25, 2012 8:58 pm
by reefcycle
Will be purchasing ph probe add on to control a port for co2 solenoid. How do I assign which ph to determine port on off. Just want to clarify this before setting up and letting co2 meltdown! Lol
Re: Ph probe add on
Posted: Mon Nov 26, 2012 4:53 am
You can use something like this:
if ( ReefAngel.Params.PHExp < 650 ) ReefAngel.Relay.Off(Box1_Port4); //CO2 Switch
if ( ReefAngel.Params.PHExp >= 680 ) ReefAngel.Relay.On(Box1_Port4); //CO2 Switch
http://forum.reefangel.com/viewtopic.ph ... ilit=phexp
Re: Ph probe add on
Posted: Mon Dec 10, 2012 4:52 pm
by reefcycle
Received package today, one question. The USB port on the expansion relay, could I plug the ph expansion into that? And if yes, how do I manually set ph calibration values like I did for main probe for this one
Re: Ph probe add on
Posted: Mon Dec 10, 2012 5:25 pm
No, that port is disabled.
You need to plug it into the hub.
For manual set the calibration numbers, use this:
ReefAngel.PHExpMin=500;
ReefAngel.PHExpMax=2500;
