Relay sticking
Posted: Tue Nov 27, 2012 9:24 pm
by reefcycle
I have a relay sticking all of a sudden. I'm going to change the port to an open slot. But how can I fix it? What would u recommend?
Re: Relay sticking
Posted: Wed Nov 28, 2012 4:55 am
It's your MH ballast, ain't it?
You can replace the relay yourself or send it for repair.
http://forum.reefangel.com/viewtopic.php?p=14834#p14834
Re: Relay sticking
Posted: Wed Nov 28, 2012 5:28 am
by reefcycle
No. Its t5 actnic. MH is perfect. I searched first and saw leds or MH usually trip it but not t5. Eh whatever I just couldn't figure out of I should bypass that port since I have extras or repair?
Re: Relay sticking
Posted: Wed Nov 28, 2012 5:36 am
I can definitely repair it with no problem if you wish.
Re: Relay sticking
Posted: Wed Nov 28, 2012 10:24 am
by reefcycle
I'll order the relay and give it a go. Off your head u think any local places would have it?
Re: Relay sticking
Posted: Wed Nov 28, 2012 1:27 pm
digikey.com or mouser.com
Re: Relay sticking
Posted: Mon Dec 03, 2012 3:03 pm
by btorrenga
What causes the relays to fail?
Re: Relay sticking
Posted: Mon Dec 03, 2012 3:57 pm
The most likely cause is in-rush current.
When current is too high, the electricity travel through the air in the form of a spark when the contacts are coming in contact, just before they close. This spark is enough to heat up the contacts that they melt and fuse together when the relay actually closes.
Re: Relay sticking
Posted: Sun Mar 03, 2013 7:55 am
by barbianj
Re: Relay sticking
Posted: Sun Mar 03, 2013 9:55 am
by DrewPalmer04
Omron G2RL-1A4-E
Re: Relay sticking
Posted: Sun Mar 03, 2013 10:13 am
12VDC coil
Re: Relay sticking
Posted: Tue Mar 12, 2013 8:16 pm
by barbianj
Thanks guys. Ordered four from Mouser.
