Arduino uploading error
- Robert1969
Trying to upload a sketch and I'm getting an upload error. Reinstalled the Reefangel installer and it recognized the USB cable.
It was working just last week.
Here is what I got when I tried to upload:
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Date/Time Setup Menu
Relay Expansion Module
Number of Relay Expansion Modules: 1
Simple Menu
Binary sketch size: 31,522 bytes (of a 32,256 byte maximum)
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Simple Menu
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM3 -b115200 -D -Uflash:w:C:\DOCUME~1\ROBERT~1\LOCALS~1\Temp\build5872358701059039420.tmp\sketch_nov19c110812.cpp.hex:i
System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv: 0 [30]
avrdude: stk500_getsync(): not in sync: resp=0x30
avrdude done. Thank you.
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Simple Menu
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Simple Menu
Re: Arduino uploading error
Are you sure it is com3?
Please check the USB-TTL cable connection
- Robert1969
Looked under device manager to make sure. Also just connected up my old board and couldn't connect to it also. Is their any way to check the USB-TTL CABLE?
- Robert1969
- Robert1969
Does the controller reboot and flash the red led status when you try to upload codes?
What about when power cycle it?
- Robert1969
- Robert1969
When I get the upload error on Arduino it states the overriding baud rate is 115200. Is that right?
not even when you power cycle it?
yes, it is supposed to override to 115200 when uploading
- Robert1969
- Robert1969
On a reboot the red light does flash, but nothing when I connect the cable
Can you check the last wire in the left?
It is the wire responsible for rebooting the controller when you upload codes.
- Robert1969
I'm boarding now on my way back.... Glad to be coming back
Let's resume this tomorrow, but by the way you re saying the controller doesn't reboot when you hit upload and that you can use the wifi attachment fine, it leads me to believe it is the cable.
- Robert1969
- Robert1969
ok got the new cable and still not able to load a code. No red light flashing or anything
