how to code "Lights ON" day or night
Posted: Sun Dec 02, 2012 8:03 pm
"Lights ON" 100% regardsless of day or night and "Lights OFF" can jump back whatever it was last time.
I see that I have now DP=90 AP=0 on the RA+ controller but I don't know what that means, I was trying things not sure how supposto be....
I navigate to and turn "Lights ON", I can see my relay ports 3 and 4 came on, the LEDs just blink once and dark (10 at evening).
I would need this when I get home, the lights started dimming down but not entirely off yet, and I need to do things in the tank.....
here is what I have now:
ReefAngel.FeedingModePorts = Port1Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 270 );
ReefAngel.Relay.On( Port7 );
ReefAngel.Timer[1].SetInterval(60);
// ReefAngel.StandardATO( Port1,62 );
ReefAngel.StandardHeater( Port2,240,255 );
ReefAngel.StandardLights( Port3,8,55,20,5 );
ReefAngel.StandardLights( Port4,9,55,17,05 );
if (hour()>=10 && hour()<19)
ReefAngel.Wavemaker( Port5,5 );
ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5));
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
ReefAngel.PWM.SetChannel( 0, PWMSlope(9,1,19,59,0,100,35,0) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(10,2,16,58,0,100,20,0) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(11,3,14,57,0,100,20,0) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(15,34,19,36,0,70,20,0) );
ReefAngel.PWM.SetChannel( 4, PWMSlope(18,5,23,58,0,100,20,0) );
// ReefAngel.PWM.SetChannel( 5, PWMSlope(10,0,19,45,90,100,1,90) );
//Float #1
if (ReefAngel.IO.GetChannel(1)) // if float 1 is triggered
ReefAngel.Relay.Off(Port8); // Turn Return off
ReefAngel.Relay.Off(Port7); // Turn Skimmer off
BuzzerOn(); // Turn Buzzer on
//Float #2
if (ReefAngel.IO.GetChannel(2)) // if float 2 is triggered
ReefAngel.Relay.On(Port1); // Turn AutoTopOff on
ReefAngel.Timer[1].Start(); // Start/Trigger timer
// Float #3
if (ReefAngel.IO.GetChannel(3)) // if float 3 is triggered
// Float #4
// if (ReefAngel.IO.GetChannel(4)) // if float 4 is triggered
// ReefAngel.Relay.On(Port7); // Turn Skimmer off
// Float #5
// if (ReefAngel.IO.GetChannel(5)) // if float 5 is triggered
// ReefAngel.Relay.Off(Port8); // Turn Return off
// BuzzerOn(); // Turn Buzzer on
// Timer 1
if (ReefAngel.Timer[1].IsTriggered())
ReefAngel.Relay.Off(Port1); // Turn AutoTopOff off
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// I/O Expansion
byte bkcolor;
x = 14;
y = 39;
ReefAngel.LCD.DrawCircleOutline( x+(a*20),y,4,COLOR_MEDIUMORCHID );
if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE;
else bkcolor=COLOR_GRAY;
ReefAngel.LCD.FillCircle( x+(a*20),y,2,bkcolor );
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 53, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 53, ReefAngel.Params );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 90, TempRelay );
// Date and Time
void BuzzerOn()
ReefAngel.PWM.SetActinic((now()%2)*100);
