ATO switch status
Posted: Sun Dec 09, 2012 7:11 pm
by ldangelo
I've looked throgh a lot of posts.
can you tell me when you say "Active" is that relay contacts closed or open?
Also where can I find a listing of all of the functions and the variables associated with them?
ie reefangel.anything(?,?.?)
is there a list of all of the functions
thanks
Re: ATO switch status
Posted: Sun Dec 09, 2012 7:53 pm
Posted: Mon Dec 10, 2012 6:13 am
by ldangelo
Thanks Roberto,
I've successfully set up a single ATO using the atolow function.
I have another switch currently plugged into ATO high and would like to use this switch to be an alarm indicating the first switch has failed. If this switch activates I want it to send an alarm and shut down the ato relay.
Can I do this in software or should I just wire the ATO switches in series so if the second switch opens (water level too high) it will shut down the relay?
Posted: Mon Dec 10, 2012 9:31 am
Which port are you using for ATO?
Can you post how you coded your ATO low?
Posted: Mon Dec 10, 2012 1:00 pm
by ldangelo
I'm not home now, at the office so I can't post the code.
I just used a one liner. I think it was single.atolow (port 1) or something like that.
It works fine. water level in my biocube 29 sump is held at level of the first float.
The second float currently plugged into ATO high isn't being used for anything.
Using the single float works great because the the hysteresis on the float switch keeps the water level constant to around +- 1/2 inch. I custom made a bracket to hold both switches and custom made a series redundant solenoid system from parts I found on e-bay. the solenoid coils are 120 VAC and it's plugged into relay port 1. I have it connected directly to my RO system
Posted: Mon Dec 10, 2012 1:39 pm
Ok, so you need to replace that line with this:
if( ReefAngel.HighATO.IsActive())
ReefAngel.SingleATOLow (Port1);
ReefAngel.Relay.Off(Port1);
Posted: Mon Dec 10, 2012 8:20 pm
by ldangelo
Thanks Roberto that worked great.
Please check my code and see if it looks ok to you.
//ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.ActinicLights( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.Wavemaker1( Port5 );
ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
if ( (hour() >= 20) || (hour() <= 6) ) // from 8p - 6a
ReefAngel.Relay.Off(Port6);
ReefAngel.Relay.Off(Port5);
ReefAngel.WavemakerRandom(Port5,240,480);
// Turn Port5 on/off random cycles that lasts from 240 to 480 secs
ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5));
// Turn Port6 on/off on opposite cycle as Port 5
// Port 5 and 6 are synchronized.
// They work in opposing motion of each other at random times.
// Adding the ATO function single switch
ReefAngel.Portal("ldangelo");
Posted: Mon Dec 10, 2012 9:25 pm
Looks good
