error: 'CurrentRelayState' was not declared in this scope
serhiyi
Post by serhiyi »
I just got my controller today and playing with code. I'm using RAGen to see how that works (trying to see what WiFi module and other settings can do for me).
I generated code and trying to load it. I got this error and can't pass over it:
C:\Users\S\Documents\Arduino\libraries\ReefAngel\ReefAngel.cpp: In member function 'void ReefAngelClass::ShowInterface()':
C:\Users\S\Documents\Arduino\libraries\ReefAngel\ReefAngel.cpp:1464: error: 'CurrentRelayState' was not declared in this scope
C:\Users\S\Documents\Arduino\libraries\ReefAngel\ReefAngel.cpp:1501: error: 'CurrentRelayState' was not declared in this scope
Am I missing something?
Thanks.
Re: error: 'CurrentRelayState' was not declared in this scop
I think you just found a bug :)
To overcome this, just make sure not to use the "Save Relay State" on the Features tab.
Then just generate the code again.
serhiyi
Post by serhiyi »
It still shows this error. What I did.
1. Opened REGen
2. Used defaults in "Features" and add WiFi
3. Used defaults in "PDE"
4. Used defualts in "Internal Memory"
5. Switched back to "PDE" and clicked Generate
6. Opened PDE file in Arduino (Reef Angel Controller)
// Autogenerated file by RAGen (v1.0.4.92), (08/19/2011 23:01)
// RA_081911_2301.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define MetalHalideSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
    ReefAngel.Relay.On(Port8);
    // Specific functions
    ReefAngel.StandardATO(Port1);
    ReefAngel.MHLights(Port3);
    ReefAngel.Wavemaker1(Port4);
    ReefAngel.Wavemaker2(Port5);
    ReefAngel.StandardFan(Port6);
Still got error
C:\Users\Sergey\Documents\Arduino\libraries\ReefAngel\ReefAngel.cpp: In member function 'void ReefAngelClass::ShowInterface()':
C:\Users\Sergey\Documents\Arduino\libraries\ReefAngel\ReefAngel.cpp:1464: error: 'CurrentRelayState' was not declared in this scope
C:\Users\Sergey\Documents\Arduino\libraries\ReefAngel\ReefAngel.cpp:1501: error: 'CurrentRelayState' was not declared in this scope
serhiyi
Post by serhiyi »
Tried with "Save Relay State" selected with same result :(
serhiyi
Post by serhiyi »
Looks like I fixed it.
I extracted all library files from RAGen installation and replaced files that I had before. Looks like this resolved the issue.
Sorry for false alarm.
Make sure the libraries folder in RAGen is setup correctly.
Go to menu Edit->Settings and look at the libraries folder and make sure it points to "Documents\Arduino\libraries"
Good you got things fixed. There was an error when you enable the SaveRelayState feature.
The error has been fixed in the upcoming .17 release and SaveRelayState will now compile properly. I have not currently tested the feature but should work as expected.
