IP Address
Posted: Mon Dec 17, 2012 4:01 pm
by xtown90
What IP address do I need for the portial and iPhone app?
Re: IP Address
Posted: Mon Dec 17, 2012 4:54 pm
by modulok
You need your external IP. whatsmyip.org is a good place to find it.
Re: IP Address
Posted: Mon Dec 17, 2012 6:00 pm
by xtown90
I used whatsmyip.org. It confirmed I have the correct ip address, but still does not work. I can see the settings when entering xxx.xxx.x.xxx:2000/wifi. Outside my LAN I can't connect.
IP Address
Posted: Mon Dec 17, 2012 6:17 pm
by dbmet
Do you have port forwarding turned on in your router?
Re: IP Address
Posted: Mon Dec 17, 2012 6:33 pm
by modulok
Yup, you need to setup port forwarding. If you did it might not be working.
Use this site to check. canyouseeme.org (change the port to 2000)
Re: IP Address
Posted: Mon Dec 17, 2012 8:19 pm
by xtown90
I used site. It says "Can not see your service on port 2000." So, I didn't set up the port forwarding correct.
