Feeding Mode
Posted: Tue Dec 18, 2012 2:49 am
Dear all need your help on this. Now when i hit Feeding Mode i want my MP10 to run at 0%(spinning slightly).
Below are the code that i use, what could be wrong? Thanks in advance!
byte WCstatus=0;
ReefAngel.AddWifi(); //Include this to setup Wifi
ReefAngel.WaterChangePorts = Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit;
InternalMemory.OverheatTemp_write( 290 );
ReefAngel.StandardLights( Port1,13,0,18,0 );
ReefAngel.StandardLights( Port2,8,0,4,0 );
ReefAngel.StandardLights( Port3,12,0,16,0 );
ReefAngel.StandardLights( Port4,15,0,21,0 );
ReefAngel.StandardLights( Box1_Port7,15,0,22,0 );
ReefAngel.RF.SetMode( ReefCrest,60,10 );
if (ReefAngel.DisplayedMenu!=FEEDING_MODE || ReefAngel.DisplayedMenu!=WATERCHANGE_MODE)
if (hour()>=15 && hour()<=17)
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(LongPulse,70,10);
else if (hour()>=22 || hour()<8)
ReefAngel.RF.SetMode(ShortPulse,50,5);
ReefAngel.RF.UseMemory=true;
if (ReefAngel.DisplayedMenu!=FEEDING_MODE)
ReefAngel.RF.SetMode(Constant,0,0);
ReefAngel.StandardFan( Box1_Port1,265,269 );
if (ReefAngel.Params.Temp[T1_PROBE] > 0)
if (ReefAngel.Params.Temp[T2_PROBE] >= 279) ReefAngel.Relay.On(Port7);
if (ReefAngel.Params.Temp[T2_PROBE] <= 275) ReefAngel.Relay.Off(Port7);
if (hour()==12 && minute()==15 && second()==0) ReefAngel.WaterChangeModeStart();
if (hour()==18 && minute()==15 && second()==0) ReefAngel.WaterChangeModeStart();
if (hour()==0 && minute()==15 && second()==0) ReefAngel.WaterChangeModeStart();
if (hour()==6 && minute()==15 && second()==0) ReefAngel.WaterChangeModeStart();
if (WCstatus==0)
ReefAngel.Relay.On(Box1_Port5);
WCstatus=1;
if (ReefAngel.WaterLevel.GetLevel()<=50 && WCstatus>0 && WCstatus<10) WCstatus++;
if (ReefAngel.WaterLevel.GetLevel()<=50 && WCstatus==10)
WCstatus=11;
ReefAngel.Relay.Off(Box1_Port5);
ReefAngel.Relay.On(Box1_Port6);
if (ReefAngel.WaterLevel.GetLevel()<=79 && WCstatus>10 && WCstatus<20) WCstatus++;
if (ReefAngel.WaterLevel.GetLevel()>79 && WCstatus==20)
ReefAngel.Relay.Off(Box1_Port6);
ButtonPress++;
WCstatus=0;
ReefAngel.Portal("Amos%20Poh");
int x,y;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 30, ReefAngel.Params );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
// Main Relay Box
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 106, TempRelay );
// Date and Time
byte WCstatus=0;
if (WCstatus==0)
WCstatus=1;
WCstatus=11;
ButtonPress++;
WCstatus=0;
int x,y;
// Parameters
// Water Level
// Salinity
// Main Relay Box
// Relay Expansion
// Date and Time
