Relay Expansion
Posted: Fri Dec 21, 2012 7:04 am
by Govertical19
Ok,
So I am setting up the expansion relay I have had for months. Just want to make sure I have it correct..
Open Head unit and put the jumpers on SDA & SCL. there is no jumper on rst?
Since I only have one exp I leave all dip switches to off.
Connect comm cable to module and new relay.
Connect usb cable from 1st relay to expansion module.
Then setup code.
All correct?
Re: Relay Expansion
Posted: Fri Dec 21, 2012 10:01 am
Yeap, except you need all three jumpers. RST also needs one.
If you don't have them and can't find any laying around, please send me a PM
Re: Relay Expansion
Posted: Fri Dec 21, 2012 2:36 pm
by modulok
This is a requirement? I didn't do anything with jumpers and my exp relay and relay box are working fine.
Re: Relay Expansion
Posted: Fri Dec 21, 2012 3:14 pm
New head units are coming with the jumpers pre-installed already.
You must have a newer model.
Re: Relay Expansion
Posted: Fri Dec 21, 2012 3:28 pm
by modulok
Yeah just got it last week.
