menus and lights
Posted: Tue Dec 25, 2012 4:40 pm
I am picking apart some code and using the pieces I like. Please explain to me what this does:
It looks like when a menu toggle is pressed it only turns off lights on the second outlet box. I will have lights on both of my outlet boxes. It obviously goes with this section:
I am still brand new at menus, so thanks in advance. BTW I am not using any of my LED\PWM ports at this time so if I don't need that part pls advise. Thx
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port3Bit;Code: Select all
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
// Date and Time
