T1,T2 and T3 Error
Posted: Wed Dec 26, 2012 8:08 am
by cjrudy
Setting up my Reef angel for the first time (Xmas present from the wife) and I am getting errors on T1, T2 and T3. I tried plugging the temperature probe into each with the same result.
Re: T1,T2 and T3 Error
Posted: Wed Dec 26, 2012 8:10 am
by rossbryant1956
plug them in and then reset the RA. (unplug and plug back in)
by rossbryant1956
be very careful with those temp probe plug ends, they are very fragile!
Posted: Wed Dec 26, 2012 8:30 am
by cjrudy
That did it thanks, connection is kind of touchy though.
Posted: Wed Dec 26, 2012 10:21 am
by cjrudy
The temp probe constantly errors out, it will stay on for a bit, then go off. Sometimes the only way to get it back on is to constantly reset. This is a pain
Posted: Wed Dec 26, 2012 10:31 am
Do the wires inside the white connector look ok or they look stripped?
How many probes do you have?
Posted: Wed Dec 26, 2012 11:55 am
by cjrudy
I have a single temp probe, the wires look fine.
Posted: Wed Dec 26, 2012 12:22 pm
Maybe you got a bad one.
Try moving it to a different port or see if the problem is a bad connection inside the white plug.
If that doesn't work, PM me for RMA number
