Error uploading Wifi Setup
Posted: Wed Dec 26, 2012 9:33 am
by cjrudy
I set up the Wifi attachment with no problem but I am trying to upload the wifi set up to the RA controller and keep getting error, any thoughts ?
Re: Error uploading Wifi Setup
Posted: Wed Dec 26, 2012 10:08 am
If your wifi attachment is already setup, you won't need to upload the wifisetup code.
Basically, there are 4 choices to set it up:
1. Using Push-Button
2. Wifi Utility
3. Wifi Setup code
4. Manually
You can pick any of the choices. Once it is setup, you don't need to do any of the others.
Posted: Wed Dec 26, 2012 10:20 am
by cjrudy
got it, thanks, although it still seems as if I cannot upload any code
