It appears as my code is not exactly how I described above. Thought I made those changes, it appears I didn't but the bulk of it is accurate. the bulk of the Water Change stuff is in the (void AutoWaterChange()) function near the middle of the code.
// Initialize Alert variables
byte AlertNonCritical=0;
byte AlertCritical=0;
byte overheatflag=0;
byte atoflag=0;
byte iochannel0flag=0;
byte iochannel1flag=0;
byte iochannel2flag=0;
byte iochannel3flag=0;
byte iochannel4flag=0;
byte iochannel5flag=0;
//*****Begin WaterChange Additions
// skimmer port
byte SkimmerPort = Port4;
// return port
byte ReturnPort = Port3;
// sump drain port
byte SumpDrainPort = Port8;
// SaltWater brute pump
byte SWBrutePort = Port7;
// Timer for countdowns
TimerClass tm;
//*****End WaterChange Additions
//*****Begin ATO By Salinity Additions
byte ATOBrutePort = Port2;
//*****End ATO By Salinity Additions
//*****Begin Custom Menu Additions
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Mask LED's On";
prog_char menu2_label[] PROGMEM = "Mask LED's Off";
prog_char menu3_label[] PROGMEM = "Mask LED's Clear";
prog_char menu4_label[] PROGMEM = "Water Change";
prog_char menu5_label[] PROGMEM = "Clear ATO Timeout";
prog_char menu6_label[] PROGMEM = "Overheat Clear";
prog_char menu7_label[] PROGMEM = "PH Calibration";
prog_char menu8_label[] PROGMEM = "Date / Time";
PROGMEM const char *menu_items[] =
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label,
//*****End Custom Menu Additions
//*****Begin Custom Menu Additions... Initialize Custom Menu
InternalMemory.write(199, 0); //sets the controller to non masked LED mode upon boot.
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.CustomVar[0]=0;
ReefAngel.CustomVar[1]=0;
ReefAngel.CustomVar[2]=0;
ReefAngel.CustomVar[3]=0;
ReefAngel.CustomVar[4]=0;
ReefAngel.CustomVar[5]=0;
ReefAngel.CustomVar[6]=0;
ReefAngel.CustomVar[7]=0;
ReefAngel.StandardFan( Port1,790,820 );
ReefAngel.WavemakerRandom( Port5,30,100 );
ReefAngel.StandardHeater( Port6,750,760 );
ReefAngel.StandardLights( Box1_Port1,13,0,23,0 );
ReefAngel.StandardLights( Box1_Port2,13,0,23,0 );
ReefAngel.StandardHeater( Box1_Port3,750,760 );
ReefAngel.StandardHeater( Box1_Port4,750,760 );
// Removes LED's from a "MASKED" State
if ( InternalMemory.read(199) == 0 )
ReefAngel.PWM.SetChannel( 0, PWMParabola(14,0,23,59,1,100,1) ); //Sets LED Drivers on Ch0 to Parabola math
ReefAngel.PWM.SetChannel( 1, PWMParabola(14,0,23,59,1,100,1) ); //Sets LED Drivers on Ch1 to Parabola math
ReefAngel.PWM.SetChannel( 3, PWMSlope(2,0,7,30,0,50,0,0) ); //Opens/closes 5V relay on Ch3 that shorts\opens dimmer leads on Ch0 LED driver to turn Driver on/off
ReefAngel.PWM.SetChannel( 4, PWMSlope(0,0,14,0,0,50,0,0) ); //Opens/closes 5V relay on Ch4 that shorts\opens dimmer leads on Ch1 LED driver to turn Driver on/off
// MASKS LED's Off
if ( InternalMemory.read(199) == 1 )
ReefAngel.PWM.SetChannel( 0, 0 ); //Sets LED Drivers on Ch0 to 0%
ReefAngel.PWM.SetChannel( 1, 0 ); //Sets LED Drivers on Ch1 to 0%
ReefAngel.PWM.SetChannel( 3, 50 ); //closes 5V relay on Ch3 that shorts dimmer leads on Ch0 LED driver to turn Driver off
ReefAngel.PWM.SetChannel( 4, 50 ); //closes 5V relay on Ch4 that shorts dimmer leads on Ch1 LED driver to turn Driver off
if ( InternalMemory.read(199) == 2 )
ReefAngel.PWM.SetChannel( 0, 100 ); //Sets LED Drivers on Ch0 to 100%
ReefAngel.PWM.SetChannel( 1, 100 ); //Sets LED Drivers on Ch1 to 100%
ReefAngel.PWM.SetChannel( 3, 0 ); //Opens 5V relay on Ch3 that removes short on dimmer leads on Ch0 LED driver to turn Driver on
ReefAngel.PWM.SetChannel( 4, 0 ); //Opens 5V relay on Ch4 that removes short on dimmer leads on Ch1 LED driver to turn Driver on
iochannel0flag = ! ReefAngel.IO.GetChannel( 0 );
iochannel1flag = ! ReefAngel.IO.GetChannel( 1 );
iochannel2flag = ! ReefAngel.IO.GetChannel( 2 );
iochannel3flag = ! ReefAngel.IO.GetChannel( 3 );
iochannel4flag = ! ReefAngel.IO.GetChannel( 4 );
iochannel5flag = ! ReefAngel.IO.GetChannel( 5 );
AlertNonCritical = atoflag + iochannel2flag + iochannel3flag + iochannel4flag + iochannel5flag;
AlertCritical = overheatflag + iochannel0flag + iochannel1flag;
if ( AlertNonCritical >= 1 ) AlertNonCritical = 5;
if ( AlertCritical >= 1 ) AlertCritical = 5;
ReefAngel.PWM.SetActinic(millis()%60000<100?AlertNonCritical:0);
ReefAngel.PWM.SetDaylight(millis()%60000<100?AlertNonCritical:0);
if ( AlertCritical >= 1 ) ReefAngel.PWM.SetActinic(millis()%300<100?AlertCritical:0);
if ( AlertCritical >= 1 ) ReefAngel.PWM.SetDaylight(millis()%300<100?AlertCritical:0);
ReefAngel.CustomVar[0]=InternalMemory.read(ATO_Exceed_Flag);
ReefAngel.CustomVar[1]=InternalMemory.read(Overheat_Exceed_Flag);
ReefAngel.CustomVar[4]=InternalMemory.read(199);
ReefAngel.CustomVar[5]=AlertNonCritical;
ReefAngel.CustomVar[6]=AlertCritical;
ReefAngel.CustomVar[7]=ATOBrutePort;
if ( ReefAngel.CustomVar[0]== 1 )
ReefAngel.Relay.RelayMaskOff=~(Port4Bit);
//*****Begin WC Additions
// If menu equals waterchange mode
// then we start the automatic water change
// Otherwise we ignore and proceed
AutoWaterChange();
//*****End WC Additions
if (ReefAngel.Params.Salinity<300)
ATOBrutePort=Port7;
ATOBrutePort=Port2;
ReefAngel.StandardATO(ATOBrutePort,40 );
if (iochannel2flag == 1)
ReefAngel.Relay.RelayMaskOff=~(Port7Bit);
if (iochannel4flag == 1)
ReefAngel.Relay.RelayMaskOff=~(Port2Bit);
ReefAngel.Portal( "00Warpig00" );
//Mask LED's On. Forces LED's On Full Blast
void MenuEntry1()
InternalMemory.write(199, 2);
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, " ");
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Mask Lights On"); waitForTime(2);
//Mask LED's Off. Forces LED's Off
void MenuEntry2()
InternalMemory.write(199, 1);
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Mask Lights Off"); waitForTime(2);
//Mask LED's Clear. Remove LED Masking Returns LED's To Normal Schedule
void MenuEntry3()
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Mask Lights Clear"); waitForTime(2);
//Start Waterchange Mode
void MenuEntry4()
//Clear ATO Timeout Flag
void MenuEntry5()
ReefAngel.ATOClear();
//Clear Overheat Flag
void MenuEntry6()
ReefAngel.OverheatClear();
//Calibrate PH Probe
void MenuEntry7()
ReefAngel.SetupCalibratePH();
//Set clock Date & Time
void MenuEntry8()
ReefAngel.SetupDateTime();
// auto water change mode
// Display Starting Water Change"
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Starting Water Change"); waitForTime(3);
// Check Saltwater BRUTE for sufficient saltwater on IO Module Port2
if ( isSWBruteEmpty() )
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Not Enough Saltwater"); waitForTime(3);
//Abort Water Change if insufficient saltwater
// Handles the cleanup to return to the main screen
ReefAngel.DisplayedMenu = DEFAULT_MENU;
DrawCustomGraph();
return;
//Display Disabling ATO Pump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Disabling ATO Pump"); waitForTime(3);
// turn off ATO pump port to prevent ATO from trying to fill a sump being drained intentionally
//Display Stopping Skimmer
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Stopping Skimmer"); waitForTime(3);
// turn off the skimmer port
ReefAngel.Relay.Off(SkimmerPort);
ReefAngel.Relay.Write();
//Display Skimmer Draining
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Skimmer Draining"); waitForTime(3);
// wait for 1 minute
waitForTime(60);
//Display Skimmer Done Draining
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Skimmer Done Draining"); waitForTime(3);
//display Stopping Return Pump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Stopping Return Pump"); waitForTime(3);
//Stop Return Pump
ReefAngel.Relay.Off(ReturnPort);
//Display Draining To Sump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Draining To Sump"); waitForTime(3);
//display Sump Filling
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Filling"); waitForTime(3);
// wait for IO Mod Port 1 to be active
waitForIOChannel(1);
//display Sump Is Full
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Is Full"); waitForTime(3);
//Display Sump Settling
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Settling"); waitForTime(3);
// wait for sump to settle
waitForTime(30);
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Settled"); waitForTime(3);
// display Draining Sump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Start Draining Sump"); waitForTime(3);
//turn on sump drain pump
ReefAngel.Relay.On(SumpDrainPort);
//display Sump Draining
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Draining"); waitForTime(3);
// wait for sump empty port active, IO Mod Port 0
waitForIOChannel(0);
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Is Empty"); waitForTime(3);
//display Stopping Sump Draining
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Stopping Sump Drain"); waitForTime(3);
// turn off sump drain
ReefAngel.Relay.Off(SumpDrainPort);
waitForTime(30);
//display Sump Settled
//display Starting Saltwater Pump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Start Saltwater Pump"); waitForTime(3);
//turn on Saltwater Pump
ReefAngel.Relay.On(SWBrutePort);
//display Saltwater Pumping
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Saltwater Pumping"); waitForTime(3);
// wait for sump full float switch active, IO Mod Port 1
//display Stop Saltwater Pump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Stop Saltwater Pump"); waitForTime(3);
// turn off sw brute pump
ReefAngel.Relay.Off(SWBrutePort);
//diasplay Sump is Full
waitForTime(30);
//display Starting Return Pump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Starting Return Pump"); waitForTime(3);
// turn on return pump
ReefAngel.Relay.On(ReturnPort);
//display Return Pump Started
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Return Pump Started"); waitForTime(3);
//display Normalizing Waterlevel
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Normalizing Waterlevel"); waitForTime(3);
//waiting 2 minutes for waterlevel to normalize
waitForTime(120);
//display Starting Skimer
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Starting Skimmer"); waitForTime(3);
//turn on skimmer
ReefAngel.Relay.On(SkimmerPort);
//display Normalizing Skimmer
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Normalizing Skimmer"); waitForTime(3);
//wait for 2 minutes for skimmer to normalize
waitForTime(120);
//display Skimmer Normalized
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Skimmer Normalized"); waitForTime(3);
//display Enabling ATO Pump
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Enabling ATO Pump"); waitForTime(3);
//Enable ATO pump
ReefAngel.Relay.RelayMaskOff = B11111111;
//display Water Change Complete
ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Water Change Complete"); waitForTime(3);
DrawCustomGraph();
bool isSWBruteEmpty()
// check status of IO Mod Port 2
if ( ! ReefAngel.IO.GetChannel(2) )
return true;
return false;
void waitForTime(int seconds)
bool done = false;
tm.SetInterval(seconds);
tm.Start();
int t = tm.Trigger - now();
do
// check the wifi interface
// wait for specified seconds
if ( (t >= 0) && ! tm.IsTriggered() )
// TODO finish countdown on screen
// show countdown on screen
//LCD.Clear(DefaultBGColor,60+(intlength(t)*5),100,100,108);
//LCD.DrawText(DefaultFGColor,DefaultBGColor,60,100,t);
wdt_reset();
delay(200);
done = true;
} while ( !done );
return;
void waitForIOChannel(byte channel)
// TODO complete this function
do
wdt_reset();
// display something on screen
delay(200);
// TODO check the IO channel logic
} while ( ReefAngel.IO.GetChannel(channel) );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,x,y,"Ch : " );
y += 10;
// I/O Expansion
byte bkcolor;
x = 14;
y = 34;
ReefAngel.LCD.DrawMonitor( 15, 44, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 44, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,76, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,76, ReefAngel.Params.Salinity );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 104, TempRelay );
