Cannot upload code
Posted: Sun Dec 30, 2012 1:48 pm
I have generated some basic code using the wizard, when I try to upload it errors. Here is the code, and the error.
And the error .............
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
Binary sketch size: 30,478 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM9 -b115200 -D -Uflash:w:C:\Users\CRUDEW~1\AppData\Local\Temp\build3507860604110621111.tmp\sketch_dec30a.cpp.hex:i
Using Port : \\.\COM9
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
InternalMemory.OverheatTemp_write( 840 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,11,30,21,30 );
ReefAngel.StandardLights( Port2,12,30,20,30 );
ReefAngel.StandardHeater( Port3,778,788 );
ReefAngel.StandardHeater( Port4,780,790 );
ReefAngel.StandardATO( Port8,60 );
ReefAngel.Portal( "cjrudy" );
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
avrdude: Recv:
