Dosing pump dont seem to be working
Posted: Thu Jan 10, 2013 8:35 am
by Amos Poh
Dear all below is my current code, the portal relay activity history states that my dosing pump is not dosing like it should be. i coded it to dose every 60min for 10 sec. any idea what when wrong with my code?
ReefAngel.AddWifi();//Setup Wifi
InternalMemory.OverheatTemp_write( 300 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.DosingPumpRepeat( Port2,0,60,10 );
ReefAngel.StandardLights( Box1_Port1,14,0,18,0 );
ReefAngel.StandardLights( Box1_Port6,15,0,17,0 );
ReefAngel.StandardLights( Box1_Port7,14,0,18,30 );
ReefAngel.RF.SetMode( Constant,50,10 );
ReefAngel.StandardFan( Port4,270,275 );
if (ReefAngel.Params.Temp[T1_PROBE] > 0)
ReefAngel.Portal( "Amos%20Poh" );
int x,y;
// Parameters
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,46, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,46, ReefAngel.Params.Salinity );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,63, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,63, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 79, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 98, TempRelay );
// Date and Time
Re: Dosing pump dont seem to be working
Posted: Thu Jan 10, 2013 10:02 am
Activity won't show on the Portal...
It's too short of duration.
http://forum.reefangel.com/viewtopic.ph ... 095#p18095
Posted: Fri Jan 11, 2013 2:45 am
by Amos Poh
Thanks Roberto :)
