Vortechs and feeding mode
Posted: Sat Jan 26, 2013 6:23 am
by vonjankmon
Question about the RF expansion module, when I activate feeding mode on my Reef Angel will it put my Vortech into feeding mode also or do I need to write some custom code for it?
Posted: Sat Jan 26, 2013 7:03 am
Should work out of the box when going into feeding mode.
Re: Vortechs and feeding mode
Posted: Sat Jan 26, 2013 7:18 am
by DrewPalmer04
Yep mine did.
Posted: Sat Jan 26, 2013 7:28 am
by vonjankmon
Awesome, thanks folks. Still waiting on my Wireless expansion since they're back ordered but trying to get everything else setup and ready to go.
Posted: Sat Jan 26, 2013 8:23 am
by vonjankmon
Is the feeding mode on a Reef Angel timed at all? The feeding mode for the vortechs is 15 minutes but it just occurred to me that I don't know much about the Reef Angel feeding mode. Is it just a manual on/off setting or is it on a timer and if so how long? If it isn't on some timer is there a way to set that up so that feeding mode ends after 15-20 minutes?
Thanks again,
Posted: Sat Jan 26, 2013 9:53 am
Its on a timer. You can change it through the portal. The ra does turn on/off the feeding mode, but if the vortechs are shorter than the feeding mode on ra, vortech will stop feeding mode first. I set mine to the longest possible and let ra handle on/off.
