Relay problem...
Relay problem...
Hi! In my relay box, Port 4 (Standar lignhts) does not Work. The RA controler show me '' the Port is open'', but the lights does not open. Until now I have never use the port 4. When i put the lights to an other open Port, the lights Open.
This is a bug or relay problem?
Re: Relay problem...
Also when i open and close the port 4 i can not hear the typical Clik that the relay does when open and close one Port.
This is my code:
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 350 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,278,280 );
ReefAngel.StandardFan( Port2,310,320 );
ReefAngel.StandardLights( Port3,13,50,22,0 );
ReefAngel.StandardLights( Port4,15,30,19,0 );
ReefAngel.DosingPumpRepeat( Port5,0,1240,10 );
ReefAngel.StandardLights( Port6,20,30,23,59 );
ReefAngel.PWM.SetDaylight( PWMSlope(14,0,21,0,10,100,15,10) );
ReefAngel.PWM.SetActinic( PWMParabola(20,0,23,59,0,100,0) );
ReefAngel.Portal( "xxxxxxxx" );
This is my code:
If it's a bad port you'll need to verify using the Relay Box test software. Roberto can advise after that on RMA or other appropriate steps. Your code looks ok...
How can i verify the relay box? what are the steps and conections? Sory to asking so mutch....
- DrewPalmer04
Sketch-> examples->relay test?
Ok i make the test and show me the prot 4 OPEN but the port does not open.... All the ather ports is Ok! Is anything i can do??
- DrewPalmer04
DrewPalmer04 wrote:Sketch-> examples->relay test?
Sorry. Tried my best off memory
- DrewPalmer04
baroutas wrote:What is mean RMA?
Return merchandise authorization AKA to get it fixed!
Could the VGA cable be missing a single connection?
Nick
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
I don't think show. I try to change the power relay (no 4) inside the main relay and if is not work then we will see!!!! Now i am in the midle of this work and i waet the spare part.....
Ok!!! I replace the power relay iside main relay (with roberto instractions) and everythink works perfect!!It is very simle Think!!! Thanks Roberto!!
Hi! Today new problem With relay box....!
1. Stop working the relay 4. when i give them the order to open and close that does not responding!!
2. When open and close relay 2, open and close relay 4 and 6 All together!!!
3. When open and close relay 6, open and close relay 2 and 4 all together!!!
4. Also When i give an order to relay 2 and after i give an order to relay 6 that does not respond and the opposite! The relay 4 still responding only when i give an order to the ather two relays!
Bug or damange from replaced relay?? Yesterday everethink works good
That looks like your svga cable is shorted out.
I think it could even be the initial problem.
If you move the cable around, does it change anything?
I change the cable with a new one and everethink works perfect!!! Agains one THANKS!!
