Installed new board
Posted: Thu Jan 31, 2013 7:00 pm
I installed my new board tonight and tried to upload the code I have been using and it keeps telling me it's too big. Any ideas why?
boolean OverrideWM=false;
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 889 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Timer[1].SetInterval(600);
ReefAngel.StandardATO( Port1,60 );
if (hour()>=21 || hour()<7)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.WavemakerRandom1( Port5,30,90 );
ReefAngel.WavemakerRandom2( Port6,30,90 );
ReefAngel.Relay.DelayedOn( Port7,0 );
ReefAngel.Timer[1].Start();
OverrideWM=true;
if (ReefAngel.Timer[1].IsTriggered())
OverrideWM=false;
if (OverrideWM)
ReefAngel.Portal( "treetopflyn" );
int x,y;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,54, ReefAngel.Params.PHExp );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
// Date and Time
OverrideWM=true;
OverrideWM=false;
if (OverrideWM)
int x,y;
// Parameters
// pH Expansion
// Main Relay Box
// Relay Expansion
// Date and Time
