Need a quick check of my code plz
Posted: Wed Feb 13, 2013 7:52 am
I've copy/pasted several snippets of code from here and just want to make sure it is all in the right place and not missing anything
ReefAngel.FeedingModePorts = Port7Bit;
ReefAngel.WaterChangePorts = Port7Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.OverheatShutoffPorts = Port6Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 790 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,9,0,20,0 );//4500
ReefAngel.StandardLights( Port2,9,0,20,0 );//RB
ReefAngel.StandardLights( Port3,8,0,23,0 );//Blue 1 & 2, Act, UV
ReefAngel.StandardLights( Port4,20,0,9,0 );//ATS
ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,15,80,15) );//4500
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,15,100,15) );//RB
ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,20,0,15,100,15) );//BLUE 1 & 2
ReefAngel.PWM.SetChannel( 3, PWMParabola(8,0,23,0,15,100,15) );//ACT & UV
ReefAngel.PWM.SetChannel( 4, PWMParabola(9,0,20,0,15,100,15) );
ReefAngel.PWM.SetChannel( 5, PWMSlope(20,0,10,0,15,70,20,15) );
if (hour()>20 && hour()<8)
ReefAngel.PWM.SetActinic(30);
ReefAngel.PWM.SetDaylight(30);
//*** Define only one mode ***
//#define TUNZE_MODE_SINE // sine wave, no pulse
//#define TUNZE_MODE_LONG // no sine wave, long pulse
//#define TUNZE_MODE_SHORT // no sine wave, short pulse
//#define TUNZE_MODE_LONGSINE // sine wave, long pulse
#define TUNZE_MODE_SHORTSINE // sine wave, short pulse
#define TUNZE_MIN 30
#define TUNZE_MAX 85
#define TUNZE_SINE_SEC 23400
#define TUNZE_SINE_SYNC false
#define TUNZE_LONGPULSE_SEC 2
#define TUNZE_LONGPULSE_SYNC true
#define TUNZE_SHORTPULSE_MS 500
#define TUNZE_SHORTPULSE_SYNC true
//PulseMinSpeed - % for minimal speed
//PulseMaxSpeed - % for maximum speed
//PulseDuration - Duration (milliseconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
//PulseSync - true if you want to sync pumps to same cycle. one false and one true if you want to anti-sync pumps.
byte TunzeShortPulse(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
byte tspeed=0;
PulseMinSpeed=constrain(PulseMinSpeed,30,100);
PulseMaxSpeed=constrain(PulseMaxSpeed,30,100);
if (PulseSync)
return tspeed;
//PulseDuration - Duration (seconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
byte TunzeLongPulse(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
byte tspeed=0;
tspeed=(now()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
if (PulseSync)
return tspeed;
byte TunzeSineWave(boolean isleftpump, byte minspeed, byte maxspeed, int period_sec) {
double x,y;
x=double(now()%(period_sec));
x/=period_sec;
x*=2.0*PI;
if (!isleftpump) x+=PI; // shift the sine wave for the right pump
y=sin(x);// y is now between -1 and 1
y+=1.0; // y is now between 0 and 2
y/=2.0; // y is now between 0 and 1
// now compute the tunze speed
y*=double(maxspeed-minspeed);
y+=double(minspeed);
y+=0.5; // for proper rounding
// y is now between minspeed and maxspeed, constrain for safety
return constrain(byte(y),30,100);
void RunTunzes() {
#ifdef TUNZE_MODE_SINE
ReefAngel.PWM.SetDaylight(TunzeSineWave(true,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC)); // left tunze
ReefAngel.PWM.SetActinic(TunzeSineWave(TUNZE_SINE_SYNC,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC)); // right tunze
#endif
#ifdef TUNZE_MODE_LONG
ReefAngel.PWM.SetDaylight(TunzeLongPulse(TUNZE_MIN,TUNZE_MAX,TUNZE_LONGPULSE_SEC,true)); // left tunze
ReefAngel.PWM.SetActinic(TunzeLongPulse(TUNZE_MIN,TUNZE_MAX,TUNZE_LONGPULSE_SEC,TUNZE_LONGPULSE_SYNC)); // right tunze
#endif
#ifdef TUNZE_MODE_SHORT
ReefAngel.PWM.SetDaylight(TunzeShortPulse(TUNZE_MIN,TUNZE_MAX,TUNZE_SHORTPULSE_MS,true)); // left tunze
ReefAngel.PWM.SetActinic(TunzeShortPulse(TUNZE_MIN,TUNZE_MAX,TUNZE_SHORTPULSE_MS,TUNZE_SHORTPULSE_SYNC)); // right tunze
#endif
#ifdef TUNZE_MODE_LONGSINE
ReefAngel.PWM.SetDaylight(TunzeLongPulse(TUNZE_MIN,TunzeSineWave(true,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC),TUNZE_LONGPULSE_SEC,true)); // left tunze
ReefAngel.PWM.SetActinic(TunzeLongPulse(TUNZE_MIN,TunzeSineWave(TUNZE_SINE_SYNC,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC),TUNZE_LONGPULSE_SEC,TUNZE_LONGPULSE_SYNC)); // right tunze
#endif
#ifdef TUNZE_MODE_SHORTSINE
ReefAngel.PWM.SetDaylight(TunzeShortPulse(TUNZE_MIN,TunzeSineWave(true,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC),TUNZE_SHORTPULSE_MS,true)); // left tunze
ReefAngel.PWM.SetActinic(TunzeShortPulse(TUNZE_MIN,TunzeSineWave(TUNZE_SINE_SYNC,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC),TUNZE_SHORTPULSE_MS,TUNZE_SHORTPULSE_SYNC)); // right tunze
#endif
ReefAngel.Portal( "Mason Dixon" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,76, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,76, ReefAngel.Params.PHExp );
