unable to upload anythinh
Posted: Wed Feb 13, 2013 7:51 pm
by emict326
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port1Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port4Bit | Port6Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.DayLights( Port2 );
    ReefAngel.StandardFan( Port5 );
    ReefAngel.SingleATOHigh( Port6 );
    if (ReefAngel.LowATO.IsActive()) ReefAngel.Relay.Off(Port6);
if (ReefAngel.HighATO.IsActive()) if (ReefAngel.LowATO.IsActive()) ReefAngel.Relay.Off(Port1);
    ReefAngel.Portal( "emict326" );
there is my code generated by the reef angle wizard, every time i try to upload it i get an errror ocured need help
Re: unable to upload anythinh
Posted: Wed Feb 13, 2013 9:20 pm
Can you check if you have the correct board and serial port on Tools->Board and Tools->Serial Port?
Posted: Wed Feb 13, 2013 9:24 pm
by emict326
i have com port 5 and angle + controller aselected
Posted: Wed Feb 13, 2013 9:25 pm
Is there any other serial port available?
I'm assuming you do have RA+, right?
Posted: Wed Feb 13, 2013 9:27 pm
by emict326
yes i do, and i just pluged in the cable and com port 5 is what it selected i am not sure what that means
Posted: Wed Feb 13, 2013 9:30 pm
Do you have more than 1 port listed? Try the other ones.
Posted: Wed Feb 13, 2013 9:32 pm
by emict326
no i do not have more than one port listed, i tryed to coppy the error codes but have been unable
Posted: Wed Feb 13, 2013 9:33 pm
Is the black wire on the very far right pin?
Posted: Wed Feb 13, 2013 9:34 pm
by emict326
i get error "class TwoWire' has no memeber named write C:\User\kevin
Posted: Wed Feb 13, 2013 9:35 pm
by emict326
yes it is
Posted: Wed Feb 13, 2013 9:36 pm
Oh, you are getting compile errors...
Uninstall the RA installer and delete the folder "Documents\Arduino"
Then download and install the new installer.
Posted: Wed Feb 13, 2013 9:40 pm
by emict326
where can i find the new ra installer
Posted: Wed Feb 13, 2013 9:52 pm
Posted: Wed Feb 13, 2013 10:10 pm
by emict326
thanks it is up and running great, and the wii fi tool was great help.
