port 8 dead
Posted: Fri Feb 15, 2013 8:14 pm
by emict326
I have had my unit up and running for 24hr, I came home and found water on the floor. port 8 that is the preloaded code return pump is no longer working the unit showes the port on but nothing works when i plug it in to that plug. any ideas?
Re: port 8 dead
Posted: Fri Feb 15, 2013 9:35 pm
Please use the ControllerTester code and check each port.
If you still find that the port is dead, pm me for repair RMA #.
Re: port 8 dead
Posted: Sat Feb 16, 2013 9:15 am
by emict326
i am at work today, i will do that tomarrow, and now port 7 does not work
Re: port 8 dead
Posted: Sun Feb 17, 2013 8:32 am
by emict326
i have run the test code and plugged in a power head to the port 7 and 8 as i toggle though it turns on, so why would the 2 stop working with other equipment on the preloaded code?
Re: port 8 dead
Posted: Sun Feb 17, 2013 10:01 am
Overheat flag, maybe?
What happens if you upload another code?
Did you try the Wizard?
Re: port 8 dead
Posted: Sun Feb 17, 2013 3:42 pm
by emict326
all of the code has been from the wizard, i can now up load any code and they work for now, but they worked fine for 24hr, before they quit
