ReefAngelContrib
Posted: Sat Feb 16, 2013 6:15 pm
by thekameleon
I have seen lots of great ideas and code snippets on these forums. Is there a community driven contrib library that can be used to compile these efforts together?
Re: ReefAngelContrib
Posted: Sat Feb 16, 2013 6:50 pm
Yes, you can work on implementing them and request a patch after you have tested it.
The original libraries are hosted here: https://github.com/reefangel/Libraries
Use the dev branch, which should be the most updated. The master is the released version.
https://github.com/reefangel/Libraries/ ... ntributing
Posted: Sat Feb 16, 2013 7:44 pm
by thekameleon
Thanks and last question... Is there a proven/best practice guide for developing... Reason I ask is. This whole thing looks to be single threaded and I assume using methods like "delay" would actually be bad thing as it could delay the rest of the processing in the loop method
Posted: Sat Feb 16, 2013 8:15 pm
Correct.
Single thread and delay is really bad practice. It will stop everything.
