Salinity temp compensation?
ahmedess
Re: Salinity temp compensation?
Post by ahmedess »
I m using the correct place now but still changing the temperature constant or even changing the salinity calibration temperature manually does not change anything in the displayed salinity value. i think its not calculating the compensation formula. heres my code that i m using in the library now:
#if defined SALINITYEXPANSION
	unsigned long tempsal=0;
	unsigned long avrgsal=0;
for (int a=0;a<20;a++)
    	tempsal+=Salinity.Read();
	avrgsal=tempsal/20;
          double SalCompensation;
		if (TempSensor.unit)
		SalCompensation=avrgsal/(1+((Params.Temp[T1_PROBE]-InternalMemory.SalTempComp_read())*InternalMemory.Alpha_read()/100000));
		SalCompensation=avrgsal/(1+((Params.Temp[T1_PROBE]-InternalMemory.SalTempComp_read())*0.001165));
	Params.Salinity=round(SalCompensation);
	Params.Salinity=map(Params.Salinity, 0, SalMax, 60, 390);
Which line are you changing?
Make sure it is the section that starts on 738
https://github.com/reefangel/Libraries/ ... l.cpp#L738
ahmedess
Post by ahmedess »
It is
ahmedess
Post by ahmedess »
I m changing the section at line 738, any clue for why is it not working
Not sure... Just wait for the update...
I'm planning to release this weekend.
ahmedess
Post by ahmedess »
I ve updated the libraries to 1.0.4 and I have a question about the salinity compensation code in the libraries
What is the use of "Salinity.TemperatureCompensation"?
void ReefAngelClass::ApplySalinityCompensation()
	// Salinity Compensation was contributed by ahmedess
	// http://forum.reefangel.com/viewtopic.php?p=7386#p7386
	// Credits to dazza1304
	// http://forum.reefangel.com/viewtopic.php?f=3&t=2670
	if (Salinity.TemperatureCompensation!=-1 && Params.Temp[TempProbe]>0)
		double SalConstant=Salinity.TemperatureCompensation;
		if (Salinity.TemperatureCompensation==0)
				SalConstant=InternalMemory.Alpha_read()/100000; // 0.0024;
				SalConstant=0.001333;
		SalCompensation=Params.Salinity/(1+((Params.Temp[TempProbe]-InternalMemory.SalTempComp_read())*SalConstant));
Here is the update log:
http://forum.reefangel.com/viewtopic.php?f=7&t=1473
The way to use the compensation is:
ReefAngel.Salinity.SetCompensation(0);
Or if you want to provide your own constant:
ReefAngel.Salinity.SetCompensation(0.0024);
ahmedess
Post by ahmedess »
You mean that i need to place the above line in my code to enable compensation ottherwise it will be disabled as default
Correct
I want to make sure we use for a while before I turn it into enabled by default.
ahmedess
Post by ahmedess »
okay I've tested the code but i have made a minor change to it. I created a memory location for the salinity constant "Alpha" and I have placed this line into my code:
ReefAngel.Salinity.SetCompensation(InternalMemory.Alpha_read()/100000);
The problem is no matter what value I set Alpha to the compensation remains the same. I have tried many values starting from 240 and changed it from 1 to 1000 and the salinity value stays the same.
However, when i change the "Salinity Temp Compensation" value to a different one the salinity changes. I've been trying to figure out why this is happening but I couldnt find a solution. Could it be this part of the code "InternalMemory.Alpha_read()/100000" the controller is not calculating properly?
Could be.
Are you sure that you are reading the correct memory location?
Just print somewhere on the screen what the controller is reading from InternalMemory.Alpha_read();
ahmedess
Post by ahmedess »
I m using ReefAngel Status to change the value in memory. I have Alpha placed in memory location 3 and when i read the value in location 3 it gets the correct value I changed it to. Do you think it might differ if i print on the screen InternalMemory.Alpha_read();
this is part of my custom memory locations in globals.h:
//custom memory locations (0-199)
#define CustomVarsStart           0
#define Mem_B_DP4Timer            CustomVarsStart
#define Mem_I_DP4RepeatInterval	  CustomVarsStart+1
#define Mem_I_Alpha			  CustomVarsStart+3
ahmedess
Post by ahmedess »
I ve done as you said and the value of internalmemory.alpha_read() changes properly to the value I set it to
I'm thinking you may have a casting issue when you are dividing the value, since it is an int value and the function calls for a double.
Try this:
ReefAngel.Salinity.SetCompensation((doube)InternalMemory.Alpha_read()/100000);
If this doesn't work, try this:
double temp=InternalMemory.Alpha_read();
temp/=100000;
ReefAngel.Salinity.SetCompensation(temp);
ahmedess
Post by ahmedess »
Finally!!
this one is working: ReefAngel.Salinity.SetCompensation((double)InternalMemory.Alpha_read()/100000);
Thanks alot
When using the compensation, do we need to set the compensation temperature as well as enabling it? I would think that we would want to tell it what temperature we plan on using but I'm not 100% positive. Could somebody clarify please?
When you enable the compensation, you should recalibrate.
It will store the temperature in which the calibration happened in the internal memory and use it as reference.
To enable compensation and use the default alpha value, use this:
Ok cool. I didn't know it stored the temperature used during the calibration.
I already have the SetCompensation(0) line in my code. I just didn't know about the temperature stored.
Does it have to be calibrated to 35ppt or can we change that value? Or does it really matter if it's calibrated to 35ppt? I believe I run my tank salinity slightly lower (around 1.024 or 32ppt).
Yes, needs to be calibrated at 35ppt and you can't change it :(
If you want to create a FlexibleSalinityCalibration() function ;), maybe others could benefit from it too :)
rimai wrote:Yes, needs to be calibrated at 35ppt and you can't change it :(
Maybe. I will see. :)
It seems like I don't even have enough time to get stuff done that I "need" to get done.
dazza1304
Post by dazza1304 »
rimai wrote:When you enable the compensation, you should recalibrate.
Quick question, where to I place this in my code - in the initialisation or loop? Sorry if a silly question!
Cheers..
setup()
howaboutme
Post by howaboutme »
hi all,
bumping this thread.
can someone confirm that this code is all that's needed (other than recalibrate) to enable temp compensation for salinity?
I'm trying to follow the initial developments in this thread but at the end it does look like the above is it?
Jack
That is it.
howaboutme
rimai wrote:That is it.
thanks!
Jack
