ERROR
cgonser
ERROR
I just got my RA+ today and I am super excited to get it all programmed, BUT every time I run the wizard, I get an error! I have been reading on the forum but dont see any fixes, so I guess for now I am DEAD in the water! I have tried to call Reef Angel but keep getting the voicemail, someone please HELP! Thanks
Dead in the Water
cgonser
Dead in the Water
cgonser
- lnevo
cgonser
Re: ERROR
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Simple Menu
Binary sketch size: 28,898 bytes (of a 32,256 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM4 -b115200 -D -Uflash:w:C:\Users\Susan\AppData\Local\Temp\build2992672625348245638.tmp\sketch_feb25b.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean,
Using Port : \\.\COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude done. Thank you.
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Simple Menu
avrdude: Recv:
- lnevo
- lnevo
- Contact:
Re: ERROR
Make sure it's connected properly and that there are no loose wires in the connector. You can also try plugging it into a different temp probe port. Otherwise Roberto might have some other suggestions for you.cgonser wrote:I have wifi connected! Any reason why my temp probe would be reading over 185 degrees??
cgonser
Re: ERROR
I have more than one temp probe and I tried another and temp seems to be correct.. Another question, I can only get the app to pull up info on my iphone when my phone is connected to the in house wifi, not when I am out of the house using the 3G...any ideas?
