Quick question about the RA - PWM ports
Posted: Fri Mar 01, 2013 4:34 pm
Hello, and thanks in advance for the answers. Quick question, I am looking at possibly getting an RA and I understand the RA Plus has 2 PWM ports. My questions is can I run 2 meanwell drivers per channel? Its my first stint messing with LED drivers so no clue what the power draw of typical led drivers is and what the RA ports can supply.
Im going to run 4 meanwell ELN-60-48P's and was hoping to run 2 drivers per channel on the RA. For moonlights I was even thinking maybe I could set 1 of the CW drivers on a relay and have them turn off at night so I can dim my blues as low as possible for the desired effect.
Any thoughts on if this will work? Again thanks in advance.
