Changes To Moonlights
Posted: Sun Mar 24, 2013 3:10 pm
I updated to the 1.03 libraries today and used the Reef Angel Wizard to generate the code. This time I did the internal memory method so I could change more options with my Android device. But during the wizard I couldn't set a custom time for my Moonlights on Port 2. I usually have these come on at 9pm and shut off at 12am. How can I change this code to make this change. Thank you!
ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.DayLights( Port1 );
ReefAngel.MoonLights( Port2 );
ReefAngel.StandardHeater( Port6 );
ReefAngel.StandardATO( Port7 );
ReefAngel.Portal( "gomer23" );
