Lighting Issues
Posted: Sun Mar 24, 2013 6:24 pm
I have everything set up using the wizzard and everything seems to be working as advertised minus my lighting. I run DIY LEDs with meanwell drivers and they are definately on, but they should be off at this time.... I want my day time lights on 0700-2100, while my actenic lighting are ran off of port 8 and should be on 0600-2200. Here is the code, please let me know if you can see an issue and why my lights are still on!
ReefAngel.FeedingModePorts = Port4Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.MoonLights( Port2 );
ReefAngel.ActinicLights( Port8 );
ReefAngel.Portal( "cgonser" );
