Logic for 3 Dosing Pumps
carlii
I would love for the portal to have logic for wireless control of a third dosing pump. I though that two pumps were enough but I find myself dosing mg now. So I have three dosing pumps. The portal make adjusting my dosing schedule much easier.
- lnevo
+1' but then I'm going to need another dosing pump
Re: Logic for 3 Dosing Pumps
It's done
https://github.com/reefangel/Libraries/issues/74
I'll need to update the Portal when the libs get released.
Piper
Outstanding! I copy/pasted the dosing pump code from the ReefAngel lib and used my own memory locs for my 3rd pump. I'll switch over to this next time I update the libs. It will be a nice to control it from the Portal (when that part is done) instead of using the Android app and trying to remember what memory locations I used
~Charlie
~Charlie
ahmedess
I would like to add a third and fourth dosing pump, one for dosing Mg and the other for vinegar. I ll be using the dosingpumprepeat function.
Do I just add these lines in the reefangel.cpp file:
and add these in internal memory:
InternalMemory.DP3RepeatInterval
InternalMemory.DP3Timer
InternalMemory.DP4RepeatInterval
InternalMemory.DP4Timer
is that correct?
void ReefAngelClass::DosingPumpRepeat3(byte Relay)
// 0 minute offset
DosingPumpRepeat(Relay, 0,
InternalMemory.DP3RepeatInterval_read(),
InternalMemory.DP3Timer_read());
void ReefAngelClass::DosingPumpRepeat4(byte Relay)
// 0 minute offset
InternalMemory.DP4RepeatInterval_read(),
InternalMemory.DP4Timer_read());
is that correct?
Just be aware that DosingPumpRepeat3() has already been added to the dev branch and is scheduled to be released on next update.
ahmedess
whens it goin to be released?
