Alternating Main Screen
Posted: Sun Mar 31, 2013 9:06 am
I want to alternate my main screen every 5 seconds from the parameter values to a chart... I am not having much luck. What am I doing wrong?
#include "Moon.h"
TimerClass screenTimer;
boolean showChart;
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port7Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPortsE[0] = Port2Bit | Port4Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port4Bit | Port7Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.AddStandardMenu();
ReefAngel.Display24h();
ReefAngel.AddDateTimeMenu();
screenTimer.SetInterval(5);
showChart = 0;
moon_init(47, -122);
ReefAngel.StandardHeater( Port1 );
ReefAngel.DayLights( Port2 );
ReefAngel.DayLights( Port4 );
ReefAngel.ActinicLights( Port6 );
ReefAngel.MoonLights( Port8 );
ReefAngel.DayLights( Box1_Port2 );
ReefAngel.ActinicLights( Box1_Port4 );
ReefAngel.Relay.DelayedOn( Box1_Port6 );
ReefAngel.ActinicLights( Box1_Port7 );
ReefAngel.Relay.DelayedOn( Box1_Port8 );
if(ReefAngel.PWM.LightsOverride)
ReefAngel.PWM.SetChannel( 0, 100 );
ReefAngel.PWM.SetChannel( 1, 100 );
ReefAngel.PWM.SetChannel( 2, 100 );
ReefAngel.PWM.SetChannel( 3, 100 );
ReefAngel.PWM.SetChannel( 4, 100 );
ReefAngel.PWM.SetChannel( 5, 100 );
else if ((hour() >=10) && (hour() <21)){
ReefAngel.PWM.ActinicPWMSlope(60);
ReefAngel.PWM.Channel0PWMSlope();
ReefAngel.PWM.Channel1PWMSlope();
ReefAngel.PWM.Channel2PWMSlope();
ReefAngel.PWM.Channel3PWMSlope(60);
ReefAngel.PWM.Channel4PWMSlope(60);
ReefAngel.PWM.Channel5PWMSlope(60);
//Moonlight Phase 9pm-10am (CH3-CH5)
//We got to dim my super bright LEDS :)
byte moon = PWMParabola(Moon.riseH, Moon.riseM, Moon.setH, Moon.setM, 11, ((MoonPhase() / 10) + 10), 0);
ReefAngel.PWM.SetDaylight(0);
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetChannel( 0, 0 );
ReefAngel.PWM.SetChannel( 1, 0 );
ReefAngel.PWM.SetChannel( 2, 0 );
ReefAngel.PWM.SetChannel( 3, moon );
ReefAngel.PWM.SetChannel( 4, moon );
ReefAngel.PWM.SetChannel( 5, moon );
ReefAngel.WaterLevelATO(Port7, InternalMemory.ATOExtendedTimeout_read(), 15, 60);
if(!screenTimer.IsTriggered())
screenTimer.Start();
if(showChart)
showChart = false;
showChart = true;
ReefAngel.Portal( "thekameleon", "265210" );
int x,y;
if(!showChart)
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// moon
x = 15;
y = 31;
sprintf(text, "%02d:%02d", Moon.riseH, Moon.riseM);
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MR:"); x+=21;
if(Moon.isRise)
ReefAngel.LCD.DrawText(COLOR_GREEN,DefaultBGColor,x,y,text);
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,text);
sprintf(text, "%02d:%02d", Moon.setH, Moon.setM);
x = 75;
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MS:");
x+=21;
if(Moon.isRise)
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 40, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 40, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,70, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,69, ReefAngel.Params.Salinity );
// ORP
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,75,70, "ORP:" );
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,99,70, ReefAngel.Params.ORP );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,81, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,81, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 91, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 104, TempRelay );
// Date and Time
int x,y;
x = 5;
y = 5;
if(showChart)
// Draws the main screen graph
ReefAngel.LCD.Clear(DefaultBGColor,0,y,131,y+69);
ReefAngel.LCD.Clear(DefaultFGColor,x,y,x,y+69);
for (byte i=6; i<=131; i+=3)
ReefAngel.LCD.PutPixel(GraphDotLineColor, i, y+25);
ReefAngel.LCD.DrawSingleGraph(T1TempColor,x,y,InternalMemory.T1Pointer_read());
ReefAngel.LCD.DrawSingleGraph(T2TempColor,x,y,InternalMemory.T1Pointer_read()+120);
ReefAngel.LCD.DrawSingleGraph(T3TempColor,x,y,InternalMemory.T1Pointer_read()+240);
ReefAngel.LCD.DrawSingleGraph(PHColor,x,y,InternalMemory.T1Pointer_read()+360);
