Fans Ports
Posted: Sun Mar 31, 2013 2:36 pm
by Bo0sted_Rafi
Im making some change from my other controller to RA and i need to know how i can code the fan port to work properly.
ReefAngel.StandardLights( Port3,12,0,2,30 );
ReefAngel.StandardFan( Port4,788,780 );
ReefAngel.StandardLights( Port7,0,30,12,30 );
ReefAngel.CO2Control( Port8,660,645 );
I need the port turns on in 78.8* and stay on until the temp drops to 78.0, the problem its when its get on in 78.6 and oscilate to 78.8, its come off. The ramp in temp its very common and the fan comes on/off over 8-10 in 2 minutes. how i can code to get the port on until get the temp that i programed?
Fans Ports
Posted: Sun Mar 31, 2013 3:09 pm
The logic is backwards. It goes low temp first then high temp.
The high temp indicates at what time exceeded it will turn on. The low temp when it turns off.
Just switch your args i think you'll be fine.
Re: Fans Ports
Posted: Sun Mar 31, 2013 3:16 pm
by Bo0sted_Rafi
Ok just switch the code and its ok? Same in the ph port?
Fans Ports
Posted: Sun Mar 31, 2013 3:26 pm
Yeah looks that way..
void ReefAngelClass::CO2Control(byte CO2Relay, int LowPH, int HighPH)
if (Params.PH <= LowPH) Relay.Off(CO2Relay); // If PH <= LowPH - turn on CO2
if (Params.PH >= HighPH) Relay.On(CO2Relay); // If sensor 1 PH >= HighPH - turn off CO2
Re: Fans Ports
Posted: Sun Mar 31, 2013 4:48 pm
by Bo0sted_Rafi
i wich part of my code i need to put those specific code?
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <ReefAngel.h>
////// Place global variable code below here
////// Place global variable code above here
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port7Bit ;
    ReefAngel.StandardFan( Port4,780,788 );
    ReefAngel.CO2Control( Port8,645,660 );
    ReefAngel.Portal( "Bo0sted_Rafi" );
    int x,y;
    // Parameters
#if defined DisplayLEDPWM && ! defined RemoveAllLights
    ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
#else // defined DisplayLEDPWM && ! defined RemoveAllLights
    ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
    // Water Level
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,54, "WL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,54, ReefAngel.WaterLevel.GetLevel() );
    // Main Relay Box
    TempRelay &= ReefAngel.Relay.RelayMaskOff;
    TempRelay |= ReefAngel.Relay.RelayMaskOn;
    ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
    // Date and Time
Fans Ports
Posted: Sun Mar 31, 2013 4:58 pm
No where..thats how the co2control function works...
Re: Fans Ports
Posted: Sun Mar 31, 2013 5:08 pm
by Bo0sted_Rafi
ok i will wait for my reactor turns off because today i get it on for about 1 week off. i let you know, thanks
