ATO single + back up
Posted: Wed Apr 03, 2013 7:11 pm
by neuro
I realized I posted in the wrong forum, so I've reposted this here:
- I want to set the ATO to single, using ATO Low to trigger the pump to feed the water to top off my sump.
- I want to set the ATO high as a backup switch, so if the first ATO low fails, the second will stop any overflow from happening.
Does anyone know what I'm going to need to do besides set my ato to single ato?
Posted: Wed Apr 03, 2013 7:47 pm
Isn't that the behavior for standard ato?
Re: ATO single + back up
Posted: Wed Apr 03, 2013 7:51 pm
Wow. I could have sworn I had posted a reply on you other thread.
ReefAngel.SingleATO(true,Port1,60,0);
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port1);
Posted: Thu Apr 04, 2013 10:03 pm
by neuro
rimai wrote:Wow. I could have sworn I had posted a reply on you other thread.
I posted in the wrong forum. Thanks Robert! I figured that was the way to do it, but didn't know if there was anything else special that needed to happen.
Thank you
Posted: Fri Apr 19, 2013 8:38 pm
by neuro
Robert, I think this only works when both switches are pointed down. If I want to have the low point down and the high point up, just like how the standard ato switches are setup, do I remove the exclamation point?
Posted: Fri Apr 19, 2013 8:44 pm
Yes :)
Posted: Fri Apr 19, 2013 9:32 pm
by neuro
Thanks, it's working now!
Posted: Mon Apr 22, 2013 7:29 am
by cosmith71
I did something similar. I wired the two switches in series. That way I have backup protection using only one ATO port. I used the other ATO port as a failsafe to switch off my return pump if the sump gets too low.
Edit: Fixed switch logic. :oops:
