Delayed Chiller/Fan startup
Posted: Tue Sep 20, 2011 12:20 am
by chase
I've noticed a significant amount of toggling as the temp bounces between the on value and below on value for my fans. Is there a way to put a delay on the standardfan option so it comes on 15 mins later or so? I was thinking about using the MH function to try and substitute but couldn't really make sense of it.
Thanks in advance!
Re: Delayed Chiller/Fan startup
Posted: Tue Sep 20, 2011 8:06 am
Can you post the function you are using?
You have to make sure to leave a certain difference for histerisys.
Posted: Tue Sep 20, 2011 7:26 pm
by chase
I'm just using code from the Tutorial:
http://www.reefangel.com/Support.Relay- ... rdFan.ashx
ReefAngel.StandardFan(Chiller,775,783); // Setup Chiller to turn on at 78.3F and off at 77.5F
I've noticed the fan toggles on and off (as a result of the temp probe reporting between 78.3 (on) and 78.2 (off). I assume the way it should work is once the temp reaches 78.3 the fans should turn on and stay on until the temp reaches 77.5?
Posted: Wed Sep 21, 2011 1:18 pm
Yes, that's how it should work.
Maybe you have something else in your code. Can you post it?
Posted: Thu Sep 22, 2011 12:17 am
by chase
Sure thing-
// Autogenerated file by RAGen (v1.0.4.92), (09/08/2011 09:54)
// RA_090811_0954.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define Daylight 1
#define Chiller 2
#define Heater 3
#define Return 4
#define WavemakerL 5
#define WavemakerR 6
#define ATO 7
#define Refugium 8
randomSeed(analogRead(0)); //wm stuff
ReefAngel.FeedingModePorts = B00001000;
ReefAngel.WaterChangePorts = B00000000;
ReefAngel.OverheatShutoffPorts = B00000101;
ReefAngel.LightsOnPorts = B00000001;
ReefAngel.Relay.On(Return); //port 4
//wm stuff
ReefAngel.Timer[1].SetInterval(random(15,35));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(WavemakerL);
// Specific functions
ReefAngel.StandardHeater(Heater,768,775);
ReefAngel.StandardLights(Daylight,9,0,21,0); //Daylight schedule 9:00am - 9:00pm
ReefAngel.StandardLights(Refugium,21,0,9,0); //Refugium schedule 9:00pm - 9:00am
//Wavemaker stuff
ReefAngel.Relay.Toggle(WavemakerL); //port 5
ReefAngel.Relay.Toggle(WavemakerR); //port 6
ReefAngel.Relay.Write();
//ATO stuff
if(ReefAngel.LowATO.IsActive())
ReefAngel.Relay.On(ATO); //port 7
ReefAngel.Relay.Off(ATO);
It's been cooler lately so the fans haven't kicked in. When I get off work I'll setup borderline temps with the ambient reading to make sure it's still happening.
As always, thanks for the help!
Posted: Thu Sep 22, 2011 8:06 am
Working as intended here.
This line is redundant though.
The function ShowInterface() calls it in every loop.
