Two pumps, randomized
Posted: Wed Apr 10, 2013 9:31 pm
by neuro
Everything I've tried that involves the wavemaker or the random() function causes me to run into "Sketch too big". I ran a simple setup before.
So I wanted to ask if anyone had an elegant solution for something I've settled on:
I want to run two pumps.
Day time:
Both randomized on their own timers, to be on for random X minutes, and then OFF for random Y minutes.
The pumps will run on timers independently by themselves.
At night:
One pump will be ON for two hours, the other OFF for two hours, and switches back and forth this way. No randomization needed.
Re: Two pumps, randomized
Posted: Thu Apr 11, 2013 3:49 pm
Maybe you will need to upgrade to RA+.
Can you post your code?
Posted: Thu Apr 11, 2013 5:44 pm
by neuro
robert,
The following code is what i currently have. it doesn't have any of the randomized wavemaker()/random() functions I was playing around with. Can you see anything I should (or should not) be doing?
// ports by name
#define halide 1
#define actinics 2
#define mainPump 3
#define skimmer 4
#define pump1 5
#define pump2 6
#define doser1 7
#define doser2 8
#define ato Box1_Port1
#define gfo Box1_Port2
#define unused3 Box1_Port3
#define unused4 Box1_Port4
#define pump3 Box1_Port5
#define pump4 Box1_Port6
#define heater1 Box1_Port7
#define heater2 Box1_Port8
#define halide 1
#define actinics 2
#define unused3 3
#define unused4 4
#define pump1 5
#define pump4 6
#define doser1 7
#define doser2 8
#define heater1 Box1_Port2
#define skimmer Box1_Port3
#define heater2 Box1_Port4
#define pump2 Box1_Port5
#define pump3 Box1_Port6
#define gfo Box1_Port7
#define mainPump Box1_Port8
// mainPump, skimmer, pump1, pump2, pump3, pump4, ato, gfo
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
// mainPump, Skimmer, all 4 pumps, all 2 dosers, ato, gfo
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port4Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit;
ReefAngel.Relay.On( mainPump );
ReefAngel.Relay.On( skimmer );
ReefAngel.Relay.Off( pump1 );
ReefAngel.Relay.Off( pump2 );
ReefAngel.Relay.Off( pump3 );
ReefAngel.Relay.Off( pump4 );
ReefAngel.Relay.On( gfo );
ReefAngel.Relay.Off( unused3 );
ReefAngel.Relay.Off( unused4 );
ReefAngel.DayLights( halide );
ReefAngel.ActinicLights( actinics );
ReefAngel.DosingPumpRepeat1( doser1 );
ReefAngel.DosingPumpRepeat2( doser2 );
ReefAngel.StandardATO( ato );
ReefAngel.StandardHeater( heater1 );
ReefAngel.StandardHeater( heater2 );
ReefAngel.Relay.DelayedOn( skimmer );
ReefAngel.Relay.DelayedOn( gfo );
static byte dayPumpMask = 5; // 0101
static byte nightPumpMask = 8; // 1000
static unsigned long cycleInterval = now();
int cycle = cycleInterval-now();
if ((hour() > 8) && (hour() < 21)) //from 8pm-9am
pumpSet(dayPumpMask);
if (cycle < 0)
cycleInterval += 1800; // every half hour
dayPumpMask = (dayPumpMask >> 1) | (dayPumpMask << 3); // Rotate right
//if ((hour() >= 21) || (hour() <= 8)) //from 9p-8a
pumpSet(nightPumpMask);
if (cycle < 0)
cycleInterval += 7200; // every 2 hours
nightPumpMask = (nightPumpMask >> 1) | (nightPumpMask << 3); // Rotate right
ReefAngel.Portal( "neuro" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 62, ReefAngel.Params,
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 107, TempRelay );
void pumpSet(byte pumpMask)
ReefAngel.Relay.Set(pump1, pumpMask & 8); // 1000
ReefAngel.Relay.Set(pump2, pumpMask & 4); // 0100
ReefAngel.Relay.Set(pump3, pumpMask & 2); // 0010
ReefAngel.Relay.Set(pump4, pumpMask & 1); // 0001
Posted: Thu Apr 11, 2013 6:19 pm
Yeah
You are just using up all the memory.
I would recommend an upgrade.
The other thing you can try is using hard coded settings, which should bring it down a little.
Posted: Thu Apr 11, 2013 8:00 pm
by neuro
thanks robert, how much more memory would i be getting?
Posted: Thu Apr 11, 2013 8:28 pm
RA+ has 256K
Posted: Fri Apr 12, 2013 8:46 am
by neuro
thanks robert, i'll consider it
