reefangel froze
Posted: Tue Sep 20, 2011 1:45 pm
last night my reefangel froze I dont know why. I've been using it for more than 2 months with the same code and this is the first time it froze. I had to unplug it from the power and plug it back on to make it run normally again.
I really don't want to risk this happening ever again cause my tank's temp rose to 84.2 deg and my lights were on all night. Thank god I didn't lose any live stock this time. I would like to know why this has happened so that i can avoid it happening again.
Also another weird thing that happened a couple of days before is that I found the status led on when it should be off while the controller was running normally. I had to turn the controller off then back on to make the status led turn off again. it didnt happen again since then but i think it might help solve the problem of why the controller froze.
I m using Dev Library version 8.5.14. I m using the pwmslope function and I m also using the delayedon function.
here is my code:
here is my code:
// Current file
// Autogenerated file by RAGen (v1.0.4.92), (05/30/2011 23:56)
// RA_053011_2356.pde
#define DosingPumpIntervalSetup
#define WavemakerSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
// Labels for the web banner
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "ahmedess";
prog_char probe1_label[] PROGMEM = "Water";
prog_char probe3_label[] PROGMEM = "LEDTemp";
prog_char relay1_label[] PROGMEM = "Sump";
prog_char relay2_label[] PROGMEM = "Fan/Chiller";
prog_char relay3_label[] PROGMEM = "Heater";
prog_char relay4_label[] PROGMEM = "Dosers";
prog_char relay5_label[] PROGMEM = "Wavemaker";
prog_char relay6_label[] PROGMEM = "Universal";
prog_char relay7_label[] PROGMEM = "Universal";
prog_char relay8_label[] PROGMEM = "TunzeATO";
ReefAngel.SetTemperatureUnit(1); // set to Celsius Temperature
// Initialize and start the web banner timer
ReefAngel.Timer[4].Start();
ReefAngel.FeedingModePorts = B10000001;
ReefAngel.WaterChangePorts = B10000001;
ReefAngel.OverheatShutoffPorts = B00000000;
ReefAngel.LightsOnPorts = B00000000;
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port7);
//ReefAngel.Relay.On(Port8); // removed to use the delayed on function
// Specific functions
ReefAngel.StandardFan(Port2);
ReefAngel.DosingPumpRepeat1(Port4);
ReefAngel.Wavemaker1(Port5);
ReefAngel.PWM.SetActinic(PWMSlope(15,0,0,30,0,95,90,ReefAngel.PWM.GetActinicValue()));
ReefAngel.PWM.SetDaylight(PWMSlope(15,0,0,40,0,50,90,ReefAngel.PWM.GetDaylightValue()));
if ( (NumMins(hour(), minute()) > NumMins(0,30)) && (NumMins(hour(), minute()) < NumMins(15, 0)) )
ReefAngel.PWM.SetActinic(0);
//ReefAngel.PWM.SetDaylight(0);
if ( (NumMins(hour(), minute()) > NumMins(0,40)) && (NumMins(hour(), minute()) < NumMins(15, 0)) )
//ReefAngel.PWM.SetActinic(0);
// Web Banner stuff
ReefAngel.WebBanner();
//delayed on for port 8 ATO
ReefAngel.DelayedOn(Port8,2);
