Wifi and standard Reef Angel
Posted: Sat Apr 13, 2013 8:39 am
by cosmith71
Is there enough memory in the standard RA to run the Wifi module, or is it better with the RA+?
Seems like I read somewhere that memory on the standard RA + Wifi was very tight.
Re: Wifi and standard Reef Angel
Posted: Sat Apr 13, 2013 9:03 am
You will be fine with RA and wifi as long as your code is not extremely complex. So, yes it is tight.
If you are concerned about memory space, RA+ would definitely get rid of the worries.
Posted: Sat Apr 13, 2013 12:01 pm
by cosmith71
Posted: Wed Apr 17, 2013 5:34 pm
by daniella3d
how tight is it? Now I am worried that if I order the ORP module it will not work. I already have the wifi module. What else can be added on top of the wifi?
Also what happen when someone hits the end of the memory?
rimai wrote:You will be fine with RA and wifi as long as your code is not extremely complex. So, yes it is tight.
Posted: Wed Apr 17, 2013 5:37 pm
Compile the code you are using and you will see how much memory you got left.
Posted: Wed Apr 17, 2013 7:14 pm
by Marco
I am a beginner, have the standard version and am running a custom ATO, have the Wifi expansion, the Salinity module and running "Reefcrest" on a WP-40. Runs like a charm.
