Newbie here
Posted: Wed Apr 17, 2013 3:48 pm
by ReefDevil
reading the directions and i have gotten stuck on step 6 of loading your initial memory settings
it says to go to file-sketchbook-example codes and select initialinternalmemory..
when i go to file sketchbook a right arrow appears but there is nothing to pick
im using a mac if that matters... i have the tools board set as RA w/ optiboot
appreciate any advice....i have printed and read alot before unboxing but seem to be stuck here
Newbie here
Posted: Wed Apr 17, 2013 3:57 pm
You need to make sure to copy the arduino folder that comes with the Mac package to your Documents folder
Re: Newbie here
Posted: Fri Apr 26, 2013 4:16 am
by johngflynn657
lnevo wrote:You need to make sure to copy the arduino folder that comes with the Mac package to your Documents folder
Re: Newbie here
Posted: Fri Apr 26, 2013 7:56 am
Did you check the user manual?
http://reefangel.com/download.aspx
Step 3 of the MacOSX section.
Re: Newbie here
Posted: Fri Apr 26, 2013 8:27 am
by ReefDevil
you pull them across the screen from left to right and drop them
